Check Engine light when placed in gear
  • Thread starter Thread starter leftturn
  • Start date Start date Jan 17, 2007
L
leftturn
San Juan, Puerto Rico
Jan 17, 2007
  • Jan 17, 2007
Hope someone can give me a heads up answer. I have a 91 notch SSP, 306, edelbrock heads, intake, #24 injectors, 70mm BBK, Proflo mass air, E cam ......... surging has always been a problem, will get it custom tuned. Recently the "stuck throttle" went away, to be replaced by a Check engine light only when placed in gear. The car is actually more drivable now. I have A Tremec 3550. At a stand still no check engine, push in the clutch and place in any gear, idle shoots up. Take out of gear, idle drops almost to stall. Replaced the IAC and the A9L. I dont have the codes, that will be next, but I am in the military in Puerto Rico and havent made any local contacts for a good 5.0 shop. Im sure there are some here, just dont know yet. Any help you can give will be appreciated. Im almost to the point of taking everything back to stock.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Jan 17, 2007
  • Jan 17, 2007
First step would be pulling the codes to see what problems your computer has stored in its memory.
this link should help you.
http://www.muscularmustangs.com/test1.php
You can pull codes using a simple paper clip. thats all u need.
5.0 Nostalgia
904
CT
Jan 17, 2007
  • Jan 17, 2007
Does this happen with relation to the clutch being pushed in? For example, when you take the car out of gear, are you using the clutch. I had a problem with my old 96 gt stalling when the clutch was pressed in. The MAF needed to be cleaned. Also, check the surging idle checklist here.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 17, 2007
  • Jan 17, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
You guys with idle problems could same a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first post has all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix!
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
