Checking P2v and flycutting questions
  • Thread starter Thread starter Marlboro_Man
  • Start date Start date Oct 10, 2006
M
Marlboro_Man
437
Houston, TX
Oct 10, 2006
  • Oct 10, 2006
1. When checking P2V should i use NO head gasket, an old head gasket, the head gasket i plan to use???
2. If the pistons need to be notched can it be done with everything still in the motor, USING A DREMEL???
:SNSign:
blkcobra50
209
  • Oct 10, 2006
:SNSign:
use the head gaskets you plan on using. when the clay is in the right position just torque the head down to 30 lbs. Get the isky tool for fly cutting the pistons. What is your combo going to be?
M
Marlboro_Man
437
Houston, TX
Oct 10, 2006
  • Oct 10, 2006
So if I use the HG's i'm going to use it won't hurt them to torque them down to 30 ft/lbs for checking P2V?
Combo will be everything in my sig plus:
AFR 165's
1.7 rr's (If they don't cause p2v probs)
new timing chain
new water pump
new lifters
new pushrods
new balancer
24# injectors
80 mm pro-m
MORE NITROUS
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 10, 2006
  • Oct 10, 2006
I always wondered what flycutting the pistons while they are still in the engine did to the balance. It seeems to me that it would throw the balance off. The pistons are supposed to weigh in at a specific weight plus or minus a gram or so. You wouldn't need to remove much metal to get out of that tolerance range.
rd
3,316
63
109
Ocean Springs MS
Oct 10, 2006
  • Oct 10, 2006
I tried a spare piston with a Dremel and decided I did not have the patience to do it that way. I got the Isky tool for the intakes, the exhausts are supposed to clear. I am going to try all this soon I hope....
This particular motor was never balanced, and the TRW pistons are supposed to be heavier than stock, so the few ounces removed should not hurt.
If this does not work, I may just do another shortblock or take it apart and get new pistons.
M
Marlboro_Man
437
Houston, TX
Oct 10, 2006
  • Oct 10, 2006
Thats a good point, I wondered about how it would affect the compression ratio accross the cylenders, if there was a slight difference in the amount taken off each piston.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
