choosing a cam questions
lmarinukjr
75
ok first of all im new to the v8 fords im a former importguy. so i need some help here my car setup is pretty much stock. here's my setup 89 5.0l coupe 119,000 miles, cold air intake 2.5'' mac h pipe 2.5'' flowmaster catback headers on the way its a mass air flow motor steeda quad. adj cable king cobra clutch kit 355 rear gears but have 4.10's ready to go in.its my daily driver. i want a cam that idles a little sloppy but stays running just so i know i have a cam.ive never done a cam so im going to need some directions on how to do one.im also going to be doing an msd setup once my income tax check comes in.
I agree with the above post. Save for heads, then you can choose the best cam for your setup. If you are going to go through all the work of swapping a cam you might as well put on some nice heads.
lmarinukjr said:
ok so what are the best streetable heads that are price reasonably
Whats reasonable to you? The best bang for your buck would probably be some GT40Ps or maybe some Thumper E7s. I would try to find some used TWs or AFRs.
Do a search on cams and heads. There is plenty threads out there on what you are asking about.
ebay usually has a few deals on gt-40's and gt40p's. Then if you wanted you could still send them to thumper to be ported. Lots of power to be had in the irons if done right.
ok i bought a set of gt40 heads that are done and a ford f303 cam and rollers.what else besides gaskets i already have the timing chain, water pump, arp head studs. what else do i need to know or do im going to put a new gt40 intake manifold and 70mm throttle body and spacer
