Clunks through the shifts
  • Thread starter Thread starter BigHairyMonkey
  • Start date Start date Feb 4, 2007
BigHairyMonkey
411
Houston (Bellaire) TX
Feb 4, 2007
  • Feb 4, 2007
As i accelerate and shift it seems like my rear end clunks (like a rough engagement), it only does this through the shifts as i completely let off the clutch. wtf? also, the t-lock seems to lock up when i get on it in a straight line (car gets sideways) but wont lock up if i try to punch it in a sharp corner (it'll just spin the inside tire). I have 3.73s, stock d/s. I've searched and so far i've found possible culprits to be U-joints.. any thoughts
blownLX5oh
42
  • Feb 5, 2007
Sounds like you may have ripped a torque box..or maybe both...look careful at BOTH torque boxes as they can be ripped/cracked and still be VERY hard to see.
Hope this helps!
Bobby
BigHairyMonkey
411
Feb 5, 2007
  • Feb 5, 2007
ill check it out, thanks:SNSign:
BigHairyMonkey
411
Feb 5, 2007
  • Feb 5, 2007
Hope this helps!
Bobby
if that is the case.. what needs to be done? rewelded?
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
2010 V8 4.6 5 speed won't go into gear while running
  • Back road driver
  • Dec 30, 2024
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jan 30, 2025
89ripper
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Progress Thread Build thread. Project Problem child. 1967 Coupe.
  • billison
  • Sep 16, 2024
1965 - 1973 Classic Mustangs -General/Talk- Mar 31, 2025
billison
