Got a spec stage 1 clutch in with rebuilt motor. Less than 100 miles since installation. First the pedal is a lot stiffer, moreso than I expected with the stage 1 clutch. Pretty dang stiff but I can live with that. My problem is taking off with a little clutch slip or especially backing up it gets a vibration that if you watch the car as your letting out on the clutch it will shake it some. Theres no denying it. Would this just be due to the clutch being new, or do I have a problem? I haven't heard any noises. The flywheel was resurfaced, torqued to 80lbft and the pressure plate was torqued to 22lb ft. Stock quadrant and cable is in use for now. In the immediate future it will be replaced. Could the quadrant be causing issues? Thanks.
