clutch prob
michaelmmiller
20
ok im taking my tranny and clutch out for the third time the first time just need a new clutch the second thought tob third trying to figure it out well its makeing a grinding noise utill u press the clutch in and then the noise slowly goes away checkd the bottom of the inside of the clutch and no metal shavings so its not the tranny or tob so its got to be the clutch right ?
RacEoHolic330 said:
I'd love to help, but I have no idea what you just said :shrug:
Basically his problem is this:
He installed a new clutch and throw out bearing. One he got the car back together, he hears a grinding sound coming from the transmission area. He checked the throw out bearing, and everything seems to be fine. The sound goes away slowly if he pushes the clutch in. When he changed the clutch, he did not resurface the flywheel.
Resurfacing the flywheel was my suggestion.
ok well anywaze im having a grinding noise in the bellhousing and its not the throwout bearing because i just replaced that and its not my tranny because i checkd to see if it was grinding metal in the gearbox and no shavings in there so i am wondering if its the clutch which prob is but i am wondering why it would do this and ps i found out that the bottom two bolts on the gearbox were loose so this prob caused something
