Clutch question
87lc2
214
Looking into buying a 94 Cobra and went to drive it yesterday. The clutch doesnt grab until the very top of the pedal travel, does that mean its on its way out? When it grabbed, it grabbed hard, it didnt slip, pop out of gear or anything. It does have a firewall adjuster, so it may just need to be adjusted, but im not sure. Also, the car will start without pressing the clutch. Just wondering if anyone can provide any insight.
Agreed with Cleston.
Adding more slack to the cable (turning the FWA CW) would move the point of engagement down.
You can look under the dash for the CSS being jumped.
Also, I'm not 100% on this but I've heard that clutchs that engage close to the top of the travel tend to wear out extremely fast... A friend of mine had an 01 Cobra and the stock clutch wore out in 25k miles with it engaging all the way at the top.
My guess is that it's caused by excessive slipping since the clutch grabs so high up? Not sure, hopefully someone has more/better information and can help out. :nice:
But yes, you just need to adjust the cable.
it's all about the adjustment. mine engages at the top too, but there is a little free play so I know the clutch isn't riding. also as an added plus you can get through the gears quicker because the pedal doesn't need to go as far down.
