Cobra Brake Question
  • Thread starter Thread starter bad68coupe
  • Start date Start date Jul 22, 2006
First Prev 2 of 2
bad68coupe
220
Richardson, TX
Jul 23, 2006
#21
  • Jul 23, 2006
  • #21
ultrastang said:
I'm not sure if I lost something in the translation or not (??) You first mentioned that you didn't want to buy the brackets, but then you say you want to buy the brackets and then copy all the measurements (??). If you bought the needed adapter brackets, why would the measurements need to be copied and then reproduced by a machine shop?
Producing your own original design is perfectly acceptable, but copying someone else's work, that they put their time and money into development and the production of the component is nothing more than piracy, which is nothing more than stealing.
I hope I just misread your statement in what you were actually saying.
What i plan on doing is no different than what companies all over the market are doing, do you think Mustang Plus, Mustang Depot, or Mustang Unlimited, or any other reproduction companies are coming up with theur own design. They simply get a original ford part and then duplicate it, which is not piracy, nor stealing, because Ford still got
degins
361
Texas
Jul 23, 2006
#22
  • Jul 23, 2006
  • #22
Reproducing a part is not quite that easy. It could easily cost $5000 to pay a qualified manufacturer to make left and right specimins, figure out the manufacturing method, and determine all the dimensional and metallugical specs. Making a one off is one thing, manufacturing (reproducing) a product is quite a bit different.
I suspect that Mustangsteve doesn't make all that much from sales of his bracket. Machine time is very expensive and those brackets are milled from billet.
If the market for these brackets is large enough, someone is going to get smart and start casting them in stainless.
bad68coupe
220
Richardson, TX
Jul 23, 2006
#23
  • Jul 23, 2006
  • #23
I am not so sure i understand what you are saying, i might be wrong but i have seen machines i guess that are in the same family as a CNC machine, and they take the measurements, and get all of the holes, and record that inforamtion onto a computer, and then you simply input those numbers into a CNC machine, and let it do its job. i believe the machine involves the use of a laser
blascrw
191
Opelika, AL
Jul 24, 2006
#24
  • Jul 24, 2006
  • #24
CMM
What you are referring to is a CMM (Coordinate MEasurement Machine) These are usually used to inspect a product to ensure it is whitin spec (tolerances).
I can be used to plot the point and then tie in to a CAD/CAM software.
I worked for a machining company (large industrial)
The equipment, software, and such is VERY expensive.
ours was designed to inspection therefore it did not work how you would do for this.
I am in no way condoning stealing someone elses work...
I will say again...you likely will not save enough to warrant this...and if you are going to buy one...reverse-engineer it and re-produce it...you are not going to save, and likely will not be able to undercut existing by any significant margin.
More power to you and good luck!
if you want a ready to go item...checkout MustangSteve, or there is another guy on ebay selling similar items...
Later
bad68coupe
220
Richardson, TX
Jul 24, 2006
#25
  • Jul 24, 2006
  • #25
Later
Thanks, i walked into this not knowing much about machining, so you have been a great help.
First Prev 2 of 2
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
Fox Brake lines hitting bump stops
  • keel
  • Sep 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
keel
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
