cobra grill insert template?
Use some 3/4" inch masking tape and offset the trapezoid shape that's already there, then cut around the inside of the tape. You'll still need to do some small trimming, but that will get you close. Wear a mask and do this in a well ventilated area if using a high speed cutter. Burnt urethane can take your breathe away.
