  • 1994 - 1995 Specific Tech
Cobra intake and injectors in GT
  • Thread starter Thread starter humphrey111
  • Start date Start date Mar 13, 2009
1 of 2 Next Last
H
humphrey111
12
  • Mar 13, 2009
I have a 94 GT and I just got a complete intake from a Cobra, including injectors, fuel rail, TB and an 80mm ProM tuned mass air. My question is, do I need the Cobra ECU for this to run right? I have seen people say as long as the MAF is tuned for the injectors it'll be ok, but others say you need the Cobra ECU. Also, if I get the cobra ECU without having the GT-40 heads will it have a problem there? Just trying to get my ducks in a row before i tear into things. Thanks
H
humphrey111
12
  • Mar 13, 2009
just realized i put this in talk instead of tech, sorry
G
ga94gt
138
Ringgold GA
Mar 13, 2009
  • Mar 13, 2009
Straight bolt on man! As long as your maf and injectors match your good. You dont need the 24lb injectors your 19's will be fine.
Dont bother with the Cobra ECU it's not needed.
Its a nice upgrade you will see a nice little SOTP feel with just swaping the intake.
H
humphrey111
12
  • Mar 13, 2009
I want to use the MAF though, and it's tuned for the 24# injectors.
G
ga94gt
138
Ringgold GA
Mar 13, 2009
  • Mar 13, 2009
Well then put the 24's in there with the maf and go on your marry way.
H
humphrey111
12
  • Mar 13, 2009
so the GT computer won't have a problem with it? As long as the MAF is tuned for 24's?
G
ga94gt
138
Ringgold GA
Mar 13, 2009
  • Mar 13, 2009
computer wont have a problem with it as long as the MAF is for 24's
Adam95GT
2,564
Burlington, NJ
Mar 13, 2009
  • Mar 13, 2009
i dont think a cobra would need a 24lb cal'd maf.... i think its done in the ecu already... so with the 24cal'd i think your fine
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,373
140
113
Foothill Ranch, CA
Mar 13, 2009
  • Mar 13, 2009
Correct, 94-95 Cobra's use the same 19lb MAF as the GT AND V6. The Cobra ECU compensates for the difference. One more cost savings for Ford - one MAF to stock for two model years.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 13, 2009
#10
  • Mar 13, 2009
  • #10
Several things to think about here
First things first
"Some People" ... are just mis-informed
Ford OEM meters are not calibrated for ANY particular size injector
That means the GT meter is not caled for 19's
and
The Cobra meter is not caled for 24's
Case in point ... I ran that little OEM meter with 30's for quite a while
And Yes ... The exact same meter is used in both GT & Cobra
Who knows how that ProM meter is setup
but
If it is caled for 19's
Well ... Consider this reasoning
An aftermarket meter with a 19# cal is like a screendoor on a submarine
It just don't make sense
The GT/Cobra OEM meter is gonna be ..........
more than adequate
more accurate in most cases
You need to be moving more air ... a good bit more air ... before the need
for a meter arises
If truth be told ... you will run out of injector
before
You run out of meter
Same kind of deal goes for the throttle body
The stocker will carry you pretty far before upgrading becomes efficient
Grady
Adam95GT
2,564
Burlington, NJ
Mar 13, 2009
#11
  • Mar 13, 2009
  • #11
your so smart grady
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 13, 2009
#12
  • Mar 13, 2009
  • #12
Adam95GT said:
your so smart grady
Not really
When I wanted to have a basic understanding of this stuff
I lurked around on sites that had smart folk who had successfully
accomplished the stuff I desired to do
Now that I think about it
I guess I'm just passing on the buck
Grady
Adam95GT
2,564
Burlington, NJ
Mar 14, 2009
#13
  • Mar 14, 2009
  • #13
final5-0 said:
Not really
Grady
learning from the best:SNSign:
H
humphrey111
12
#14
  • Mar 14, 2009
  • #14
thanks for the info guys. i bought all the stuff from the same guy so the maf is tuned for that setup, just on a cobra. looking forward to getting it all put on.
Adam95GT
2,564
Burlington, NJ
Mar 14, 2009
#15
  • Mar 14, 2009
  • #15
from my understanding the maf cant be "tuned" the ecu is tuned, mafs can be cal'd to work with the stock ecu settings for a certain # injector however
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Mar 14, 2009
#16
  • Mar 14, 2009
  • #16
Now Grady you and I know full well the size of the tb is directly dictated by the size of the hole on the intake. I mean choosing a tb based on cfm vs. how cool it sounds saying 70/75mm, well the choice is obvious.
H
humphrey111
12
#17
  • Mar 14, 2009
  • #17
well yes, calibrated. that's what i mean, nothing to really tune on a MAF
G
ga94gt
138
Ringgold GA
Mar 14, 2009
#18
  • Mar 14, 2009
  • #18
Missinformed i dont think so, I think yall need to read what he said its a Pro-m meter caled for 24's. Yes I understood what he ment because you dont tune a Maf.
I told him that he didn't need to run 24's but he wants to, so please tell me why not use the meter when it is set up for 24's?
And yes to answer your question everything you have will work with no problems.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 14, 2009
#19
  • Mar 14, 2009
  • #19
ga94gt said:
Missinformed i dont think so I think yall need to read what he said its a Pro-m meter caled for 24's. And yes to answer your question everything you have will work with no problems.
Now ... Now ... Now
No need to be defensive
Nobody was directing anything negative in your direction
I was refering to the original post Mr. humphrey111 posted
He said ... "I have seen people say"
and
That is the group of peeps who I feel are mis-informed
Ask me how I know
Why not share your knowledge with the rest of us
Grady
G
ga94gt
138
Ringgold GA
Mar 14, 2009
#20
  • Mar 14, 2009
  • #20
Sorry Gardy, I thought that was directed at me like I was giving fasle info.
I ran almot the same set up except it was with a Pro-m 77mm I belive it was with 24lb injectors and it ran just fine maybe a little rich but it did fine
1 of 2 Next Last
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
