Cobra intake and injectors in GT
I got a bit more time now to talk about this stuff :D
Lets back up to the beginning :)
Lets look at this from the perspective of the aftermarket meter folk
which in this case is ProM
or maybe is PMAS :shrug:
or whatever they call themlelves these days :shrug:
Maybe some of you have seen peeps talk about the ... Cheat Method
of calibrating a meter which the aftermarket folk started
I know ... I mean ... You gotta know by now :Word:
You have seen myself and others repeat over and over :crazy:
OEM Ford meters are not caled for any particular size of inj ;)
:eek: I'm a gonna try and tie all this stuff together :shock:
Most likely JT, Greg, Wes, or some other member
is gonna have to bail me out on this one :rlaugh:
BUT
I'm gonna strive to keep it very basic and simple with this post :spot:
Of course ... we can talk more later :D
One last warning :)
It will be simple
It will be kept very basic
BUT ... It will be a bit long as it is a good bit of info to deal with :crazy:
We are gonna look at 94-95 applications only here folks :Word:
just know this :eek:
Fox folk don't have to deal with the same issues ;)
therefore
Most of the fox meter/inj talk does not apply to us 94-95 folk :nono:
Also ... AFPR's/elevated fuel pressure will N O T be present here :nono:
Main topics we are gonna deal with will be ............
1) OEM GT meter application
2) OEM Cobra meter application
3) Aftermarket meter manufacture ... Cheat Method
4) A bit of injector size application
btw ... A fairly simple but good article can be found on my site about the C M
if anyone wants to get all the details :)
1&2 First ... We all know it is the exact same meter on both cars
yet
GT has 19's and the Cobra has 24's
Meters measure air ... Plain and Simple
Aftermarket meter folk make peep think fuel is in the mix as well :nono:
A stock GT will generate only so much airflow
and
A stock Cobra will generate that much and a bit more
If you grasp that fact, then consider the additional amount of airflow of
the Cobra is not enough to render the meter ineffective
That is all there is to that ... no need to talk any more :nono:
except to say
That is why the exact same meter works just dandy for both cars :nice:
Now ... We can't run on airflow only :D We gotta have a bit of fuel ;)
4) Injector size requirements are not the same for both cars
It ain't Rocket Science my gearhead friends :nono:
Cobra makes more power and needs more fuel
R E M E M B E R ... we are talking 39 pounds of fuel pressure here
therefore
Don't be mislead by the OLD SCHOOL FOX mechanical tuning method
Honestly ... If hosing around with fuel pressure was the Bees Knees :banana:
Don't ya think we would'a seen Ford equip our cars with AFPR's ;)
OK #3 ... Last Topic of discussion
Is anyone still reading this novel :rlaugh:
The Aftermarket Meter Folk know and depend upon several facts
a) They know info about OEM meter capibilities
b) They know info about the size of inj used on the car
c) They know how much airflow is generated by how much hp
d) Most important of all ;) They know about OEM pcm parameters :Word:
They use what is called the Cheat Method to try and make things so
you don't have to go inside the pcm and change things when you
want to use one of their meters
You gotta know this was first done with the older Fox Stangs :D
Worked fairly good for them boys for years :)
Unfortunately ... Works not so good for us :(
We won't go there but its all about our pcm's being load based
and
The older Fox pcm's are focused around rpm
Now ... Say you have modded your Stang beyond what the tiny OEM
19's can safely deliver fuel at ... OEM ... or 39#'s of pressure
Again ... you don't have pcm access
therefore
Even though the meter will handle the additional airflfow .....
You need larger injectors :bang:
so
You get a meter from ProM ... Calibrated (Cheat Method) ... for larger inj's
The Cheating part is ...........
They lie or tell a fib to the pcm about how much airflow is really flowing
through the meter :eek:
A simple way of looking at it might be :D
We got 2 Stangs we will use for example only :)
One has 200rwhp, 20# inj's, moves 500 kg of airflow, OEM pcm
The other is being built and its owner estimates it wil make about
300rwhp and wants to avoid a custom tune
He calls ProM and they base their findings off these facts ...
PCM THINKS he has 20's and can move a maximun of 500 kg airflow
ProM knows he might REALLY generate around 1000 kg of airflow
They reccomend him to use 40# injectors to safely allocate enough fuel
They rig up the meter to report 1/2 or 50% of actual airflow
Are you starting to see how things are working out here ;)
Inj's are twice as big as the pcm thinks :eek:
but
Meter only reports half of the REAL airflfow to the pcm :shock:
therefore
The pcm commands a smaller pulsewidth due to the lie the aftermartket
meter boys setup in the meter to account for the larger size inj's
Well ... There it is my friends :D
btw ...You most likely have seen the folk who have access to the pcm
talk about the maf transfer curve :scratch:
In a nutshell :)
Thats where they tell the pcm the ... TRUTH ... about generated airflow :Word:
AND
They tell the pcm it no longer has those tiny 19's :nono:
Man O Man ... I'm done for now :banana:
I either helped or made it clear as mudd :rlaugh:
Ask away if needed and I will try to help :shrug:
or
Maybe someone can fix my messed up attempt to splain this stuff ;)
Grady
