Cobra lost power after installing Crane 2031 cam
I hope everything turns out well.
I am having to rebuild my stock cobra engine due to the previous owner neglecting to do anything about the vibration from the engine due to a bad balancer. I am going to install a 2031 cam and do some minor home porting on the stock gt40 heads while I have it apart. Mainly smoothing the short side radius and smoothing the valve guides and port matching. I have a tweecer r/t and some free dyno time so I'm gonna do my own dyno tune after I get it all together.
Thanks, I hope so too. I'm having him dyno the car without the chip tonight. We'll see what happens. He basically told me that he didn't think it would make any difference, but I told him to do it anyway. (Customer is always right) :D
I have seen more than a few people with stock gt40 heads and intake with no port-work making some decent gains in hp with this cam. I just don't understand why I'm not. The car is in great running condition with only 70,000 non-abused miles and regular oil changes with synthetic. I even gave it a fresh tune up since the last time I had it dyno tuned.
Yeah I think the power will be all in the tune myself. If they won't reburn the chip you'll probably end up having to take it somewhere else to get it done unfortunatly. I hope it all turns out well.
There is nothing worse then paying for work to be done only to find out the place doing the work didn't do all the things they were expected to do. This is the reason I do most of my own work.
Well, I talked to the tuner yesterday morning and asked him to do a dyno run w/out the chip. I could tell he was a little insulted that I was questioning him about the way he tuned it, but I don't really care. I told him that I would prefer that he tuned it though the ecu instead of doing it manually. He said he didn't think taking out the chip would make any difference, so hopefully he follows through with it. He hasn't gotten back to me yet. I'll let y'all know how it goes.
Been workin WAY too much lately :crazy:
Sooooo ... haven't had any time to see what all has been goin on :shrug:
but ... I have been curious if you are getting things all sorted out and it looks
like you are makin some headway :nice:
Hey ... you paid for a service and you didn't get what you consider a fair
rate of exchange
I'd not feel all that bad for speaking up like you have done
He needs to know you expect things in a certain way and not just some
generic or run of the mill kinda tune
Just basic or general info about my Week End 95 GT Toy tune :)
I run about 36 total spark and its all in by 2500
I run the mix at about 12.75 to 1.00
I got the tip in retard nulled out
A note about the above info would be ...........
I run just a tad more squeeze with
the small AFR chambers
a cut on their decks
and hg's that are a bit on the thin side
It all boils down to the fact that ..........
I gotta pump in the 93 stuff which is kinda costly these days :bang:
If you go less aggressive on the spark ...........
you might be able to run a lesser grade of go fast juice ;)
Hope you find a bit more power in the new tune :banana:
Grady
Well things were looking better, but now I have a whole other issue. Last night the tuner dyno'd the car without the chip. The peak numbers went from 254rwhp to 257and the torque went up from 298 to 306 with a A/F ratio of around 12.3-12.5 to 1 and initial timing was manually set at 14*. The shop only charged me for the cam install and didn't charge me for the 15 dyno runs they made with the car. The car picked up a ton of midrange power just from removing the chip. Anyway, I picked up my car and it seemed ok, no stalling or surging. I noticed from the tuner bumping up the fuel pressure with the stock system the open loop a/f ratio at half throttle was about 16 to 1 instead of the 14.7 to 1 that it should be, so that gave me a bit of a hanging idle between shifts and at stop lights. Other than that and the dang timing retard between shifts the car seemed like it was running pretty well untill I pulled into my driveway. I put the car in first gear and rolled on to the gas to pull into my garage and the car kind of bogged and didn't react to the throttle. I thought maybe I'll disconnect the battery to reset the computer overnight and see if that would stop it.
Here's where it gets bad. I reconnected the battery this morning and started the car to pull it out to wash it. The car started fine and then died after I pulled it out. I started it one more time and it died again. I left it sit for awhile and tried to start it again and now the car won't start. :( I don't know what to do now. I pulled the fuzes out of the power distribution box and they all looked fine. I rechecked the connections to the computer and I couldn't find anything wrong there either. I think my computer may be all f'd up but I don't know what to do. Any suggestions please!! The car is cranking and there is plenty of juice from the battery, it just wont fire up. What should I look for?
you definitely should have gained power, I don't have dyno numbers cuz I'm running untuned (just advanced the timing and adjusted the TB) and I saw a nice gain at the flashlight drags (1/8 mile racing on an air strip, set up just like street racing, only it is legal and sanctioned, no timeslips though). I used to lose badly to my buddy with a built 01 GT with a built auto and stall and now I am dead even with him and even nosed out a half fender win end of last season against him. I'd say maybe your shop didn't properly degree the cam. This really doesn't make any sense, to be honest I'd go with the suggestion above to check and see if the swap was even actually done. Does the car have a choppy idle? If not, I would say there's a good chance you've got yourself a stock cam still.
just saw your new post.
Was the car running fine until it warmed up? Mine did that when we first got the swap done, Idled and ran like a champ while pulling it around to the front of the shop, but once it warmed up and went into closed loop (stopped dumping fuel) the car bucked and died. The only thing I had to do was manually adjust timing to 16 degrees and I played with the air bleed screw on the throttle body (essentially creating a really small vacuum leak) until it idled consistently. I have had it stall on me on occasion at a red light here and there (maybe once in every 50 lights), but thats no big deal to me, I will be getting a full tune after I finish my H/C/I, LT's, maf, TB, injector, and gear build.
I am positive the swap was made. I got back my old cam, springs, and pushrods. The car did have an awesome lumpy idle, but now it won't start at all. :shrug: The car felt like it picked up some midrange, but it was raining last night so I couldn't get on it too hard. If the cam was degreed improperly I think I would have noticed either poor low end power or poor top end power. This doesn't seem to be the case.
Right now I have the battery unplugged and I'm waiting to try it again tomorrow, but I don't know what else to do.
I think I will see a lot more power with a good tune if I can get this thing started.
Hopefully that will work out for you, it sucks to see this not working out for you. If it's not the degreeing or the tune, I honestly will be baffled... Obviously, a cam with stock heads will never yield major power gains, I didn't expect them nor did you, but you certainly should make more than a couple extra hp, and you damn sure shouldn't lose any power. The only thing a cam should make noticeably different is the RPM range of the power, and also a power increase. I did notice the mid range power of mine fattened up considerably, which you said you also noticed.
Dunno man, keep us posted.:flag:
I tried to start it again last night after I had the battery unplugged for several hours. On my second try of cranking the motor for several seconds it fired up for about 5 seconds and then died again. I even removed my computer and checked all the connections and everything looked ok.
When I look at the big picture, only two things were done to this car that may keep it from cranking over.
1. The fuel pressure was bumped up with the stock regulator (Against my wishes).
I would have rather had the car running lean untill I was able to get it tuned by a REAL tuner. Does anyone know how to set the pressure back to stock?
If I'm looking at it right, it is a little dial behind and to the left of the distributor. I think it is located between the distributor and the upper intake manifold. There is even a hose coming out of it that says high pressure fuel.
2. Would the ignition timing set higher keep the car from starting? Do I need to reset it to a base of 10? I wouldn' t think I would, but I'm stumped.
I tried to start the car again this morning after resetting the computer. I actually got it fired up and it ran for about a minute. After the RPM's droped below 900 the car died. I couldn't react quick enough to give it some gas. I tried to start it again and it just cranked. I noticed when I tried starting it again I heard the fuel pump kick in twice. I heard two buzes. What does this mean? Is it some sort of safety device turning the pump back off or what? I don't understand why I would hear it twice with my key in the on ignition position. Usually you hear it turn on once before you start the car.
Just when I got excited about getting it running she took a crap on me again. I wish I would have stayed in the car and gave it some gas instead of getting out to open the garage door. But then again If it would've kept running I would have been afixiated by the fumes. :D
Anyway I unplugged the battery again trying to reset it. I'll go back out and check it in a few hours. In the mean time any suggestions about how to get this thing started would be appreciated. I'm about to have it towed to the dealer soon if I can't figure it out.
I know you checked things around the area of the pcm but it sure sounds like
there may be a bad connection since things have been disturbed a good bit
all around that area lately.
I'd look at the service port since he pulled the old chip out to see if anything
looks out of line.
You kinda need to keep WOT conditions separated from cruising around town.
If you are at a light to medium load .....
a mix greater than 14.7 is not uncommon.
At WOT ....... a mix of low 12's would most likely be a bit fat :(
As for the dizzy being at 14
You really can't tell a whole lot by that kinda thing :nono:
You don't have a clue about what is going on with your spark unless you know
how he is making his adjustments :scratch:
See ... here is the deal with spark on SBF's since their inception
Well ... first ... lets just cover the basics :)
You got total amount of spark
Then you got how it is controlled
Now ... back to SBF's :D
They've always produced max WOT power at 36 give or take a few
and
You'll always pick up power if you get it all in quicker
Now ... having said those two things ... lets talk about our pcm 94-95 Stangs
The amount and rate of advance is controlled by the spark tables in the pcm
If you don't have pcm access ... you can't obtain both of those objectives
Allow me to post up an unmodified spark table from a 94-95 Cobra
First ... A bit of basic info for those who've never seen such a table :)
On the left side you see load with bottom idle and top WOT
Across the top you see the rpm
All values are as they are with the fact the dizzy is set at OEM value of 10
What you basically would do is ..........
Increase the value in the top row (WOT) to around 36
and
Have it come in quicker by being all in by 2500 or there abouts
Now ... look at what happens if you don't have pcm access
To obtain your best WOT performance you want 36
sooooo
You have to twist the dizzy an additional 10 to obtain the 36 total
That just won't be a possibility as the mid load values will be too high because
when you do the ... dizzy twist dance ... its a global kinda thing and its in effect
at all loads.
That much of an increase will wreak havoc with your mid load values :crazy:
and
Most likely produce the dreaded ... ping thing :bang:
Of course ... it goes without saying .............
Twisting the dizzy will do nothing about the rate of advance as well :(
Summing up :D
In your case ... if he was only doing mechanical tuning :shrug:
You would add 4 to ALL values as he bumped the dizzy setting up by 4
Basic Stuff Really :)
Maybe some will find it helpful :shrug:
Grady
Thanks Grady that puts it all into perspective and I completely agree with you that it would have been much better to tune through the computer. That's why I want to get this car to a competent experienced stang tuner. As far as checking connections, I disconnected the three wiring harnesses and pulled the computer. The j3 port looks fine and nothing appears to be loose there. I also checked all the pins on the computer and none of them are bent. There might be a broken wire or something up in the firewall area, but nothing that I can see from the limited space under the glovebox/passenger floor area. It would really help me if someone knew how to set the fuel pressure somewhere around normal. I know this will be hard to do since there is no gauge on the stock unit.
The only things I can think of are:
1. a bad connection
2. The increased fuel pressure may be screwing with the computer and not allowing proper start up.
3. My computer is fried.
The only things that made the car start for a short time were unplugging the battery overnight to reset the computer and taking the computer out and reinstalling it. I got the car to run for about a minute after I unplugged the battery overnight, but as soon as the rpm's dropped down toward normal idle the car stalled out. :shrug:
Thank god I'm a triple A member. I'm going to have to give them a ring and have the car towed to a shop to do a diagnostic test. I just hope they can find the problem. If it's a wiring thing it could take hours just to find a bad connection.
To me it seems like I'm getting plenty of spark but not the correct amount of fuel. I can smell gas while cranking the car, but it just won't turn over.
95riosnake, do you happen to have the phone # of SGS Performance. I heard you and another member saying they did great work and I wanted to get my car tuned there after(if)? it's up and running. I went to the website and got the number, but when I dialed it said the phone number was no longer in service. Any idea what it is?
Thanks
if you have the stock regulator how did he adjust the pressure? at this point if everything was installed properly you should check the fuel pressure and verify you have spark. the part by the intake and distributor is the schrader valve. get a gauge and hook it up there.
A quick pcm reset procedure for you
Disco the neg batt cable
Turn on the headlights for 15 seconds
Turn off the headlights
Reinstall the neg batt cable
PCM Reset ... Done
I've heard of it done many ways and taking as little as 5 min. to reset and as much as several hours to reset. Every aftermarket company claims something different I guess. Chip manufacturers such as diablosport say to disconnect the battery and hold the brake pedal down for about 30 seconds to reset fuel values. To be on the safe side I disconnected the battery, turned on the headlights, and held down the brake. I have let the battery unplugged for as little as 2 min. and as long as overnight. Either way, the car will not kick over, so resetting it at this point is doing no good.
