Cobra R's Best Size and Offset
dcurtis
688
Have a bone stock 93 Gt Hatchback, going to upgrade the exterior with a new hood, fenders, wing and wheels, already ordered a straight 3inch cowl hood, and a saleen wing, and now for the wheels, I want 17 inch Cobra R's but not sure on the correct width or offset, what size and offset would fit and look the best? Deffanatly want a wider rear wheel whithot the rubbing
Thanks for any Help???
I would go 17x9, 24mm offset, 255/40/17 all around. That will allow you to lower the car a bit with no rear rubbing. You will get a little rub on the front when turning at full lock, but its really not a big deal.
Where would you recommend for the best deal on the Cobra R's, I would prefer the standard aluminum ones not the chrome ones or the polished ones, Summit has them for 146.95 a piece plus shipping which I forgot how much that was, where can you get a rack limiter from?
I have the Ford Racing 17x8 Cobra R's. The tires are 245/45/17 fronts and 275/40/17 rears with the quad shock. Only thing I had to do was get Maximum Motorsport adjustable lower control arms (rear) so I can raise the rear a couple of inches because of the wide tire hitting the fender and I did not want to roll the inner lips.
Got pics?
