Code 29-Insufficient input veh speed sensor
my$100project
208
Just as thread says. Just wondering where to start, and possible problems. a diagram and location of this sensor would probably be helpful as well. Thanks in advance for any help.
Also code 81-Inlet Air Control Circuit malfunction.
a quick note: I do have a multimeter handy and access to a fluke 98 scope.
Code 29 - Vehicle Speed Sensor (VSS) is an electronic sender mounted on the speedo pickup gear on the trans. It works the cruse control for both 5 speed and auto trans cars. The VSS is used to tell the computer to speed up the idle as you slow to a stop. This helps keep the engine from stalling when you slow down for a stop sign or stop light.
Check to see if the electrical connector is plugged into it. Clean the connector & contacts with non flammable brake parts cleaner prior to replacing the sensor, as that may fix the problem. The sensor cost is under $30 and it is easy to replace.
Code 81 – Secondary Air Injection Diverter Solenoid failure AM2. The solenoid valve located on the back side of the passenger side wheel well is not functional. Possible bad wiring, bad connections, missing or defective solenoid valve. Check the solenoid valve for +12 volts at the Red wire and look for the Lt Green/Black wire to switch from +12 volts to 1 volt or less. The computer controls the valve by providing a ground path on the LT Green/Black wire for the solenoid valve.
See http://www.veryuseful.com/mustang/t...ng5.0Vacuum.gif for help on the vacuum line plumbing.
Reactions: Mrg2783
Hey, @jrichker hoping you can help, I'm stumped, I keep getting code 29c. Been this way for months.
I have gone through two new vss sensors that both tested within ohms range, cleaned the harness connector and tested continuity from the harness to pin 3 and pin 6. I have continuity on both wires.
Anything additional you can suggest? Possibly it's the computer at this point?
Thanks
Thanks
More than likely it is the wiring or connector.
Do you have a DVM or Multimeter and know how to use it to measure resistance?
Using the diagram below, find the wiring for the VSS sensor.
Measure the resistance of each wire from where it connects to the VSS sensor to the correct pin on the computer.
Check the gray/blk wire (computer pin 3) to the gray/blk wire on the VSS sensor.
Check the pink/orange wire (computer pin 6) to the pink/orange wire on the VSS sensor.
You should see less than 1.5 Ω resistance.
Computer wiring harness connector, wire side
Computer wiring harness connector, computer side
The following are diagrams courtesy of Tmoss & Stang&2birds
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
HVAC vacuum diagram
Fuse box layout
Starter circuit
Thank you very much! Always appreciated.
HVAC vacuum diagram
Fuse box layout
Starter circuit
Just an update for anyone in the future, I broke down and bought a third VSS and sure enough, it fixed the issue.
I guess the VSS measuring within ohms doesnt mean it is necessarily good.
Third times the charm apparently.
Thanks for the help @jrichker
Hi I’m having the same issue with my car. I have a 1992 Mustang GT with a fresh build 308 and an A5 transmission. I swapped over the the Dakota digital dash so I know longer have a speedo cable but I have the VSS sensor in place and plugged in. I don’t think I have a gear in the tranny bc again I’m using a Dakota digital dash set up. I’m getting code 29C as well. I will check the resistance in the wires previously mentioned but now that I think about it. If there is no gear in the tranny to spin the VSS sensor, then the sensor isn’t really doing much to tell the computer that the car is moving hence why I stall coming to a stop when pushing In the clutch? My idle is good and it drives good. I still need a tune to make it perfect. Did a base idle reset and set the timing and fuel pressure.
My set as follows:
308 with flat top forged pistons
Fresh built stock bottom end
SVE heads ported and polished
1.6 trick flow rockers
Comp cam hardened push rods
New Ford high performance lifters
Ford E cam
New comp cam timing chain
Edelbrock high flow water pump
Trickflow upper and lower street burner manifold
3.5” Anderson power pipe
30# injectors with the proper calibrated MAF
A5 transmission from astro performance
Dakota digital dash
Live wire wires, NGK plugs, screaming demon coil, MSD distributor
Etc....
Just a little about my ride since I’m new on this site. Thanks in advance for your help. @jrichker
-Ron J.
Pull the sensor out and shine a flashlight up the hole. You should easily see a speedo gear centered in the hole about 4-5" in.
Without a functional VSS on mass-air equipped cars, some will report stalling when coming to a stop. Correct the VSS issue and that will go away.,
Well, you want it to be somewhat accurate.
What rear gears and tires are you running? They sell speedo kits that are a matched pair and at least get you in the ballpark.
ALWAYS use a new clip to secure the speedo gear. DOn't use a used one. After flexing from an install or two, they like to break causing the speedo gear to walk and then not make contact. Total PITA after you've just installed a trans. SO always use a new clip.
For example, if you have 3.73's...
Oh ok. The gear will have nothing to do with my speed. I thought that was the gears only purpose besides providing a signal to the VSS? I honestly don’t know the gears in my rear end. I haven’t had to get in there yet.
It won't have anything to do with your speedometer, but it does tell the ECU your speed so that it will know when you are coming to a stop. I'm sure for that purpose it doesn't need to be 100% accurate, but you don't want to be waaaay off either.
At a minimum, you need the drive gear, and a clip
For the cost, you might as well just buy the entire kit that matches the gear you have in the rear and be somewhat "correct" even if you aren't using it to drive a speedometer
