coils
  • Thread starter Thread starter cheeks
  • Start date Start date May 9, 2005
C
cheeks
262
  • May 9, 2005
Hello,
I was just wondering about a coil to go with my msd 6al ignition box...From what i can see there are two different types...a tfi stock looking type and a canister type...Which kind should i use??...(I don't really like the idea of hearing a buzzing noise from the tfi unit though)...This iginition will be used to fire a 408 N/A carbed motor if this helps...what does everyone think??thanx...
D
Daggar
3,902
  • May 9, 2005
I'm thinking that your stock coil is more than up to the task of an N/A setup with a reasonalbe RPM range.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
May 9, 2005
  • May 9, 2005
Unless you were having trouble with your stocker... you should stick with the original and your MSD box.
Once your stocker goes, then you can replace it.
EMI should be able to be eliminated with a better ground on the coil.
Edit: I would like to add... My stock coil did die and I bought a Crane PS91. Pluged right into the stock harness. It does give off EMI, but I am too lazy to ground the thing. Maybe tonight when I pull codes to find out that my EGR is sticking...
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
May 9, 2005
  • May 9, 2005
I have the MSD blaster TFI coil. no probelms.
i have also ran the accell version too, no problems there either.
the canister style isnt a direct replacement, so i woiuld stick with the tfi style for now.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
