I am experiencing a cold start problem that started about 8 months ago. On a cold start, after sitting overnight. I can start the car and it will fire right up and then it will spit and sputter then die. then I restart and it will run just fine. Now the last few day, after a cold start it does this several times and then will run. After the initial warm up the motor starts just fine, no problems. It does not do this all the time, it seems like it goes in spurts. Any Ideas what could be causing this?
I also found that after I turn the car off I lose feul pressure too, I believe it should hold some pressure for a wile. I have a new BBK adjustable feul regulator and a Walbro 155 LPH feul pump. Also the feul pump and Ford Racing 24 LB injectors are 5 years old and have about 8000 miles on them). I do have a Walbro 190 LPH that I am replacing it with.
Could this be attributing to the funky cold start problem? It seems like it is allways something! But I've had this Mustang 23 years and it is far from stock, So I have to take the good with the bad.
Any Ideas on what my problem could be and how to fix it would be appreciated as allways
