  • 1994 - 1995 Specific Tech
combo opinions-suggestions
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Dec 25, 2006
DDSTANG94
465
FRASER, MICHIGAN
Dec 25, 2006
  • Dec 25, 2006
Alright guys I finally think I have my combo picked out, here's what I have , Afr 165's, crane1.7 pedestal roller rockers, performer rpm intake, 65mm throttle body, and full exhaust with shorties, and 3:73. So far Ive bought the afr, performer rpm intake, and 65mm throttle body, and exhaust.
I think this is a pretty good combo but I'm having a little problem deciding on a cam, Ive searched through old threads and I think i'm going to go with the tfs stage 1. This cam is rated to 5500 rpms, but the performer rpm intake is rated to 6500 rpms. Is this a bad choice of cams considering this mis-match. I know picking the write combo is key. What about an alphabit cam? anyone running afr heads, preformer rpm, and trick flow cam.
I know everyones going to tell me custom grind, but i dont have the money,..
bimmertech
1,123
merriam, ks
Dec 26, 2006
  • Dec 26, 2006
i have 165's, trick flow track heat intake(1500-6500 like the rpm), and stg 1 cam. it all works very well together and i have no problem pulling to the rev limiter.
i would go stud mount instead of the pedastal rockers, and if you think you need more cam just retard the tfs1 4 degrees.
MattZ281LE
345
Purcellville, Va
Dec 26, 2006
  • Dec 26, 2006
Almost Identical to my old combo.
I had the Crower 15511 cam though and a ported Cobra Made 306/330 at the wheels no tuning.
Yes do stud mount, it is a PITA to get the right geometry on pedastals. It took shims and diff pushrods for me to get mine right AND A LOT of time. trial and error.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
