1 BADD 92 said:
I'm going to pull the upper intake this weekend and see what I see. It only makes sense since I don't see the oil going anywhere else. I just thought that 1 qt every 2 weeks was more than just the pcv. We will find out I guess.
Thanks all
I know I'm coming in late, but here are some of my thoughts.
If you are losing oil via the pcv your hoses will be wet with oil, and you will find oil on the inside of the intake manifold.
You should be able to see the oil in the intake by manually opening the throttle body, and peaking inside.
You will need to install the baffle on the valve cover.
You won't see the oil traveling through the clear tube when you let the car idle, as it is not idle that pushes oil out of this location. Oil will blow out of the TB/VC line on Overrun at high rpm's.
Installing a $25 Home depot oil separator on the pcv line will confirm if the oil is coming through this line. A carb fuel filter should work as well, but the separator can actually stop a larger quantity of oil.
Other concerns.
Rings - Low tension rings may make decent compression numbers, but will still yield up to 20% leakdown. This is why a leakdown test is beneficial.
Age/mileage of the engine has little influence on leakdown.
Valve Seals - If the intake valve seals start to fail, then intake vac pulls oil directly from the top of the heads.
Just my quick thoughts,
jason
