Consuming 1qt oil every two weeks
  • Thread starter Thread starter 1 BADD 92
  • Start date Start date Oct 30, 2006
First Prev 2 of 2
1 BADD 92
#21
  • Nov 1, 2006
  • #21
Again, Thanks to all for the great info. I am going to strip the upper intake off this weekend and see what I see. The more and more I think about it, the PCV seems to be the issue. The motor was not rebuilt with low tension rings and I will do a Leak down this weekend also. Compression is great and the plugs are clean so I don't see any one particular cylinder out of balance with the others except for #8 which is a tad darker than the other 7. Will let everyone know what I find this weekend. Again, thanks everyone, this is the reason I come on here, everyone is willing to give a guy a hand or just throw in their 2cents.
vristang
4,933
101
124
Seattle
Nov 1, 2006
#22
  • Nov 1, 2006
  • #22
wythors said:
That someone was me. The baffle applies only to the Chinese-made manifolds. I just reinstalled my lower with the new baffle on it and it took care of my oil consumption problem.
1BADD92, if your manifold is one of the newer, Chinese Cobra intakes, PM me and I'll fill you in on the details of getting the baffle and what is entailed in the install.
I don't suppose you snagged a pic of the new baffle?
I would love to see what Ford came up with.
If you don't want to post it, feel free to email it.
I host/post the pic.
:SNSign:
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Nov 1, 2006
#23
  • Nov 1, 2006
  • #23
No, I didn't take a picture before I installed it. The part number is F6TZ-6L678-AA. The intake came with a small (3x3) baffle mounted at the rear and another smaller one covering one spot on the driver's side. The new piece covers almost two thirds of the underside of the intake from the rear forward. It appears to have fixed the problem, but is a far cry from the "really easy to install, it'll just take a couple of minutes" that the guy at FRPP told me. Both the old and the new baffles are riveted in and the new one requires that an additional hole be drilled for mounting. I've got a good relationship with my local machine shop and my guy there took care of it for me for next to nothing.
vristang
4,933
101
124
Seattle
Nov 2, 2006
#24
  • Nov 2, 2006
  • #24
Thanks for the info.
It sounds like the new Ford design is pretty large
SamSnyder
196
#25
  • Nov 2, 2006
  • #25
With that much oil consumption and no obvious broken parts I'm gonna vote for a massive gasket leak under the intake manifold, letting oil get sucked right into one or more intake ports. I had a mismatch using the Felpro 1250 (I think) on stock sized ports that allowed air (and oil) to get sucked right into the ports under the manifold. I'd pull the lower as well as the upper and give it a good hard look, including looking for a mismatch on the intake gaskets. I just don't think that much oil could get sucked up the PCV no matter what you do.
1 BADD 92
#26
  • Nov 2, 2006
  • #26
Sam, normally I would agree with your theory but if I had a big leak at the lower intake and the oil getting sucked into the combustion chamber. The I would see smoke out the tail pie and the plugs would show oil fouling which neither is happening. So I am right back to the PCV
Thanks
vristang
4,933
101
124
Seattle
Nov 2, 2006
#27
  • Nov 2, 2006
  • #27
Thanks
It depends on how much oil is passing through the combustion chamber.
Low levels of oil can burn off completely, whether they enter the combustion chamber through the pcv, valve seals, or lower manifold/head gasket.
Don't dismiss ANY possibility untile you have ruled it out.
One way to check for a bad lower manifold gasket is to remove the pcv and put a vac gauge on it.
Besure to plug the intake leak you have created, and run a vac gauge so that you are registering pressure/vac from the crankcase.
With the pcv removed there will be no source of vac to the crankcase.
If all is well with the lower intake/head gaskets, then you should see a pressure on the vac gauge.
If you see a vac signal, then most likely that gasket is the culprit.
jason
1 BADD 92
#28
  • Nov 2, 2006
  • #28
This is true and I will rule out all. My conclusion was that if I am burning such a large amount of oil and it is coming in through the lower intake gasket then it would not be in vapor form and would more than likely show on the plugs, however if it is coming in from the PCV then more than likely it will be more or les vapor form and will burn off more readly as you stated.
Man, I love this forum. Such a wealth of knowledge from everyone.
I will be tearing the upper intake down this weekend and we will see what it ends up being.
Thanks everyone
First Prev 2 of 2
Y
Engine Oily cylinder- bad lifter relationship
  • Yoyoda
  • Nov 9, 2024
Fox 5.0 Mustang Tech Nov 16, 2024
Yoyoda
Y
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
W
Blue smoke..
  • Wicked_Rpm
  • Aug 11, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 14, 2024
weendoggy
Resolved Coolant blowing out of valve cover??
  • sav22rem22
  • Nov 1, 2023
5K
Fox 5.0 Mustang Tech Nov 19, 2023
sav22rem22
Timing not advancing/retarding
  • PonyGTrider
  • Aug 16, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2024
