Convertible pump
Find a used unit. Ford used the same pump from 1965-1993 in convertible Mustangs. When the pump went in my 93 I swapped the spare I have for my 65 in. Works like a champ.
Also, verify that the lines to your lift cylinders aren't broken and/or leaking. Those plastic lines get brittle and split or snap off after awhile. You can buy a new set of lines from 50resto for like $35 ... or you can be ghetto like me and just use fuel line with fuel injection hose clamps. :D
I had one explode in my face 2 days ago, it sucked...
The pump has been going out for awhile. About two years ago, it did not have the balls to lift the top, so I used power steering fluid vs the ATF made the top work but now the motor is fried. I can hear the relay click and nothing else. I applied 12volts directly to the pump motor and the power supply spiked @ 20 amps, so I am pretty sure the pump is done.
