coolant temp sensor
  • Thread starter Thread starter bobbys9350
  • Start date Start date Mar 18, 2007
bobbys9350
472
  • Mar 18, 2007
hey guys i got a painless wiring thermostat kit for my new SPAL electric fan. i have a holley systemax intake. i dont see a second hole for the thermostat to thread into. any ideas? thanks!
Fett
766
  • Mar 18, 2007
Are you looking for a place to put a new sensor? How about drilling and tapping the top of the thermostat housing? That is where I put the VW switch I used for my Taurus fan. Worked great.
HISSIN50
34
129
Mar 18, 2007
  • Mar 18, 2007
Fett has the right idea. I'd add that you can get a cast stat housing from the parts store for 10 bucks. It has a 3/8" NPT hole tapped in it.
Good luck.
bobbys9350
472
  • Mar 18, 2007
Good luck.
excactly what i did. thanks for everyones input!
stangster50
129
cranston ri
Mar 18, 2007
  • Mar 18, 2007
on mine, there is 2 threded holes in the back of the lower intake also with 2 square drive "bolts" plugging them.... why couldnt these be used? its what im planning on using..
bobbys9350
472
  • Mar 18, 2007
DIFFERENT INTAKE
HISSIN50
34
129
Mar 18, 2007
  • Mar 18, 2007
Those work okay for a useless gauge or something you dont care about (NOT a fan switch). Coolant flow back there is very limited (it changes due to radiant heating/cooling more than anything else). This means the fan would be slow to turn on and slow to turn off. Not good. I used the driver's side rear port for my stock temp gauge and that worked alright since that gauge is useless anyhow.
Just MHO.
Good luck.
P.S. If you need to, you can remove those plugs with the upper intake in place (in case it saves some work).
stangster50
129
cranston ri
Mar 19, 2007
  • Mar 19, 2007
oops.. i just noticed what intake he was running..
thanks... i was thinking that, to be honest thats why i posted that. i didnt want to seem like i was hijacking the thread.. i have the water neck with a threaded piece in the other engine i have, so thats what ill use.. thanks.
Flavadave4
1,044
21
49
Utica, NY
Mar 19, 2007
  • Mar 19, 2007
sounds like an easy solution Hissin50 stated
Engine Fan temp sensor location.
  • 7-UP BILL
  • Apr 3, 2026
Fox 5.0 Mustang Tech Apr 7, 2026
KRUISR
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
