Cooling Fan Options
  • Thread starter Thread starter JD1964
  • Start date Start date Oct 8, 2017
First Prev 2 of 2
General karthief
Mod Dude
Aug 25, 2016
28,129
10,748
213
polk county florida
Oct 10, 2017
#21
  • Oct 10, 2017
  • #21
Stock alt is ok with stock clutch fan, stock stereo, stock pullies.
Just make sure the plug with the three wires is in good shape, the earlier years, 87-88-89's, had some issues with the plug burning up so check it for burnt, discolored wire connections.
A 3g upgrade doesn't hurt.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Oct 10, 2017
#22
  • Oct 10, 2017
  • #22
If you upgrade the fans to electric you need to do the alternator upgrade. Its fine for a stock set up...but check the wires per karthief. I used a Taurus alternator and re- clocked it. It fit the stock bracket with very little modification. There are two different sized alternator bodies. The pulley is bigger than the stock fox pulley....so I pulled one off a 90s escort.
The alternator in my car now is bigger and only fits because of the aftermarket alternator bracket. It was for a fully loaded 96 Taurus.
The one for a fox is from a 94 3.8 Taurus. Its a fairly easy swap. Run a new 2 ga power wire to a 150amp fuse and holder to the positive terminal or starter solenoid, run a 2 ga. battery wire from the block to the negative battery post, 2 ga. to the body from battery ground. The small wire D connector is the same....just cut the white/black stripe wire ( about 3 to 4 inches ) from the D connector, put a wire spade on it and plug it in the 3g alternator. The wire goes from the D connector in the alternator back into the alternator.
The two black/ orange stripe power wires for the old alt. can be completely removed.
Reactions: General karthief
JD1964
there is enough sticking out to grab on to
3,637
1,658
194
Maryland
Oct 11, 2017
#23
  • Oct 11, 2017
  • #23
Lots of good info there, thanks.
Steel1
Mustang Master
Aug 18, 2017
1,419
639
143
Connecticut
Oct 11, 2017
#24
  • Oct 11, 2017
  • #24
There's a member over on Corral forums that was selling nice 3G alternator/wiring kits.
Not sure if there still available but I bought one years ago and it worked out great.
Found the link:
http://forums.corral.net/forums/ele...nator-upgrade-complete-kit-small-case-19.html
JD1964
3,637
1,658
194
Maryland
Oct 12, 2017
#25
  • Oct 12, 2017
  • #25
I’m stubborn and I don’t even need to admit it because you all know. You’ve proven me wrong before and maybe you will again. But I’ll be rogue again.
I’m going with the flex fan for now. It weighs 2.5 lbs less than the stock clutch fan (including spacer and hardware) and it’s also a little quieter. Moves a ton of air at idle and the blades flatten out considerably by 3k rpm.
Not into an alternator upgrade that would be needed for the electric fan setup.
Haven’t test driven with flex fan due to rainy day but I’ll keep you posted.
imp
Mustang Master
Jul 13, 2017
531
107
83
Oct 12, 2017
#26
  • Oct 12, 2017
  • #26
@John Dirks Jr
I've seen flex fans make a helluva lot of noise. Seen partly-stuck clutches drive fans loud as airplane propellers, too. Have you thought about a smaller than stock plastic job with a clutch? They make them in inch-increments. imp
manicmechanic007
5 Year Member
Sep 26, 2017
2,567
727
143
Roy, Utah
Oct 18, 2017
#27
  • Oct 18, 2017
  • #27
mikestang63 said:
john, it's hard to beat the stock clucch fan. unless it is not cooling I would leave it be.
if you want a E fan,I would go with the contour dual fan and a FAL 33054 controller
The fan fits the radiator perfect and pulls well over 3300 cfm
My sentiments exactly. If it's making noise (and the bearing is not loose), that means its working correctly. I advise leave it alone/ I have switched my 69 to electric.
Reactions: imp
manicmechanic007
5 Year Member
Sep 26, 2017
2,567
727
143
Roy, Utah
Oct 18, 2017
#28
  • Oct 18, 2017
  • #28
I have run a lot of flex fans over the years. They make me feel a bit uneasy when timing one at 3800. I like them though, and you do not have to time them all at 38.. They are pretty
imp
Mustang Master
Jul 13, 2017
531
107
83
Oct 19, 2017
#29
  • Oct 19, 2017
  • #29
You switched to electric, and are not completely happy? Why? imp
First Prev 2 of 2
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Which cooling part first?
  • Dontknowchit
  • May 8, 2025
2K
Fox 5.0 Mustang Tech May 15, 2025
90trunk
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
  • dan50
  • Jul 18, 2026
dan50
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
