  • 1994 - 1995 Specific Tech
Cooling problem
  • Thread starter Thread starter rfw0002
  • Start date Start date Aug 11, 2005
R
rfw0002
Houston Tx
Aug 11, 2005
  • Aug 11, 2005
I've searched for info and can't find an answer to my cooling problem.
1994 mustang gt--afco aluminum radiator--8 months old, new mr. gasket 180 deg thermostat, new overflow tank and all bumper air delector in place. Even performed manual fan swith mod and car still goes over the L in normal after it warms up and I am at a stop. If I'm going down the freeway w/ a/c on--it stays at the L in normal. I know w/out a mech temp gauge--I don't really know what the temp is, but I always fear that my car will overheat. Running 50/50 water and coolant. If I have the radiator cap off (which is also new), there are no bubbles in coolant and I dont see any movement of the coolant. Can a water pump go bad w/out fluid leaking from weep holes? Also, when I turn on the fan switch--my temp gauge jumps immediately. Oil pressure gauge also pegs out. Possible short or other electrical isssue? Sorry for the long post, but no sure what to do next.
HISSIN50
34
129
Aug 12, 2005
  • Aug 12, 2005
Welcome to the boards! Wait, this is your first post and you have been a member for a couple years?
I would get a mech gauge on there, as you noted. Not becuase the stock guages suck, but because yours are particularily sucking. Your car might be fine temp-wise, but you are having an electrical issue going on.
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 12, 2005
  • Aug 12, 2005
It's odd that your temp shots up along with your oil pressure gauge.
CManT1914
3,172
Killeen, Texas
Aug 12, 2005
  • Aug 12, 2005
Yea if your gauges are doing that kind of crap, I'd say it's an electrical issue, and not an actual cooling issue. Get an AM gauge on there, and see what it's really running. They're not expensive.
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
