cooling question
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Jul 4, 2007
M
MattTheBat83
203
  • Jul 4, 2007
last night i was in a drive thru line for a long time, like 20 mins, and the temp gauge went to about 250-260. i have a stock water pump, stock fan, and stock radiator. do i need to upgrade or is there something else?
cenok is family
1,409
69
79
Norman, Ok
Jul 4, 2007
  • Jul 4, 2007
what thermostat you using? sitting for 20 mins is a pretty good amount of time just sitting. you might want to invest in a bigger radiator. how old's your waterpump? all my stock stuff has been fine for me so far, but i'd like to get an aluminum radiator eventually.
M
MattTheBat83
203
  • Jul 4, 2007
the water pump has like 7000 miles on it the radiator is like 3 years old
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 4, 2007
  • Jul 4, 2007
Did it cool down once you start moving?
Still running stock fan setup? Hows the clutch? If you spin it by hand, does it spin very easily? If so, replace the clutch.
RYC CUKR
1,437
Orlando
Jul 4, 2007
  • Jul 4, 2007
It sounds like a fan clutch issue. In general if you heat up while sitting in traffic or in a drive thru in you case it is an air flow issue i.e. bad fan clutch no shroud stuff like that.
If it heats up while driving its a coolant flow issue or missing air deflector. My 88 was fine in traffic or while stopped but when you would get going down the road at 55 or 60 it would slowly heat up. The stock radiator was clogged up. Flushed the engine and put a new aluminum 2 core in and it stays right at 185* during the summer with the AC on in Florida.
HISSIN50
34
129
Jul 4, 2007
  • Jul 4, 2007
I agree. If it cools at speed but soaks when you're idle, the clutch is likely. A clutch on the outs will often seep silicone around the hub (thermal clutches use silicone as a viscous coupling, modulated via a bi-metallic spring).
Check your fan blade for cracks while in there - replace as necessary (FAL makes a metal replacement blade which works very well).
Good luck.
M
MattTheBat83
203
  • Jul 4, 2007
i bought the police interceptor fan clutch should i replace the fan with one of those flexlite fans or is it not worth it?
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 4, 2007
  • Jul 4, 2007
I beleive the PI clutch only works with the stock fan. The flex fans directly bolt to the water pump if i recall correctly
HISSIN50
34
129
Jul 4, 2007
  • Jul 4, 2007
If the flexalite fan blade question was for me, you certainly could do that. FWIW, I think Mike and I are talking about different items. He is talkin about a flex fan (most folks run one with a spacer in lieu of a clutch) and I'm talking about a replacement fan blade (but it's metal, which is neat to me). The one I use accepts a fan clutch just like the stocker.
If your fan blade has cracks (the OEM blade was known for them - really check it over because you dont want that POS breaking at 5K RPM), then I think the new fan blade is 35 bucks well spent.
We should add: If you need a fan clutch and fan blade (or even just the clutch - a HD or SSP version is upwards of 100 bucks), consider an E-fan and 3G alt. YOu can get both for 100 bucks or so (or less) at a J/Y. It is a nice upgrade, though I'm actually a proponent of mech fans for cars that dont tach up much. If you like to tinker, it's a fun upgrade.
Good luck.
M
MattTheBat83
203
#10
  • Jul 6, 2007
  • #10
took a look at the fan and yea its got some serious cracks in it. can anyone recommend what kind of blade to get its going to be used with a police clutch
HISSIN50
34
129
Jul 6, 2007
#11
  • Jul 6, 2007
  • #11
In case it helps:
I'd need to doublecheck my paperwork but I think the Flexalite 5918 is what I used (it's FLX-5918 on Summit).
M
MattTheBat83
203
#12
  • Jul 7, 2007
  • #12
so i bought the police interceptor clutchi even bought a ne fan blade cause there was a big crack in the old one... temp is still high... coolant is full so i bought a new thermostat. the car runs at about 200 w/ a 180 but if it sits it gets to about 250 any ideas would help
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 7, 2007
#13
  • Jul 7, 2007
  • #13
What's the condition of the radiator?? Is it fairly new? Are the fins bent?
What about the coolant? Is it fresh? 50/50 mix or 75/25?
HISSIN50
34
129
Jul 8, 2007
#14
  • Jul 8, 2007
  • #14
And if you happen to know, if you hold the RPM's at 1500-1800, does it cool down or get hotter?
Unless your radiator is shot (which would have shown you hot operating temps across the board), your new fan clutch and fan should be doing well. Was the fan installed facing the correct direction (pulling air rather than trying to push it forward)?
Black1987Stang
1,422
Jersey Shore
Jul 8, 2007
#15
  • Jul 8, 2007
  • #15
I have a stock water pump, bone stock radiator, clutch (locked up), fan, with a 195 thermostat, the highest I've seen with the engine running is 205-208degrees. Although the locked up clutch might be sucking in a little more air than normal, I also have underdrive pullies which will slow down the speed a little. I have a Taurus 2 speed electric fan im waithing to put on, just need a 130 alternator, I have a spare taurus fan in my classifieds if you're interested. I would put on an electric, youll have better mpg and more power (much less rotating mass on the crank)
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
