Well I was just wondering what it came out to be for you guys. Since I want to know if I am in the ballpark range of how much money I will need. The heads I am most likely going to be getting will be used edelbrock performers for around 800-900.
The other stuff ill need is:
Cam (either TFS1 or Crane 2031)
Fuel pump (255 lph)
Maf
Injectors (ill be using 30lb injectors since i will be running a 75 shot of nitrous and i can also get them for free)
Lifters
Rocker arms
Hardened push rods
Timing Chain
Throttle body
Headers
Head gaskets
Header gaskets
Intake gaskets
Fluids
Also a Tune
So am I leaving anything off this list of what is needed and just as I asked above, what were some of the dollars you shelled out?
Fuel pump (255 lph)
Maf
Lifters
Rocker arms
Hardened push rods
Timing Chain
Throttle body
Headers
Head gaskets
Header gaskets
Intake gaskets
Fluids
Also a Tune
better be ready and you didn't mention which intake you wanted
........... I could ............
