Crane 2030
  • Thread starter Thread starter NKau
  • Start date Start date Aug 25, 2006
NKau
1,346
Jefferson, WI
Aug 25, 2006
  • Aug 25, 2006
Just want to know how many people have had good experiences running this cam in a street car that sees limited 1/4 mile action.
I'll potentially be running this cam with 1.90/1.60 eddy rpm heads, 1.6 ratio roller rockers, the regular eddy performer intake, 24 lb. injectors, bigger maf & tb, 1 5/8 longtube headers through a 5-speed with 3.73's out back.
I know it's an older cam design, but I've seen a couple set-ups similar to what I plan with the edelbrock heads, etc. that were running pretty easy mid 12's (with 1.8/1.9 60 ft. times).
Just hoping that it will not be too bad of a cam on the street.
NKau
1,346
Jefferson, WI
Aug 27, 2006
  • Aug 27, 2006
C'mon......nobody?
whtpny
338
Spokane WA.
Aug 27, 2006
  • Aug 27, 2006
Call Crane and get there advice. I do not see any reason why it would be a problem at all. They may recommend something newer.
G
gt90stang
568
  • Aug 27, 2006
I run the 2030 with Edelbrock Heads with 2.02/1.6 valves and it works great on the street. I went with it because it has an EO # for CA emissions legal. You'll have to check the piston to valve clearance.
Don
NKau
1,346
Jefferson, WI
Aug 27, 2006
  • Aug 27, 2006
Don
Cool. Are you pretty happy with performance below 3000 rpm, or is it pretty soggy? I'm assuming you have a 5-speed...........
G
gt90stang
568
  • Aug 28, 2006
NKau,
AOD, 2500 Stall 9.5" converter and 373s. I've ran it NA and now 8psi Boost with a KB Blowzilla. Never bogged in either case with a nice flat torque curve. It runs about 10" vacuum at idle (676 RPM) in drive and 12" vacuum in neutral at idle.
Don
NKau
1,346
Jefferson, WI
Aug 29, 2006
  • Aug 29, 2006
Thanks for the feedback Don, much appreciated.
G
gt90stang
568
  • Aug 29, 2006
NKau,
Yeah, no problem. Just wish the tires didn't spin so easy, well I've only got 275/40R17 Nitto 555R drag radials That cam really pulls from 2K to 5.5K. Idle is slightly loopy but idles good at 672 RPM with lots of Tweecer tuning.
Good Luck, Don
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
