crank seal
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
any one have tips on how to get the crank seal to seat into the timing cover with it in the car? i spent about an hour on it with it in the car last night thinking i need something like a 2 inch cup that i can tap on the center and have it seat that way
I always center the old seal on top of the new one and then tap it in with a mallet. Use grease to help it go in.
+1. same for seating a rear main seal, just place the old one over top and CAREFULLY tap it in to place with a rubber mallet...pretty much the only good way to get it in there
i will see if i can find my old seal... dont see how that will help though. as i went around the seal lightly tapping on it it would keep popping out of the other side. think i need to be tapping from the center of it
sometimes i put a nit of silicone around the sealing surface that seems to help it stick. and yes use a cup if you can or get a 2x4 and drill the center out so it fits over the crank and tap that. just dont tap directly on the seal with a hammer it is very likely that you will bend or warp it which could drastically reduce the life of the seal.
just my .02
