I set the timing to 10 deg before TDC, put the plug back in, timing goes back to where it should be.. I let it run for a minute or 2, watching the mark on the crank, timing creeps back up to 10 deg or MORE ?????? Fresh built 306, mild port E7 heads, cobra intake, 70mm bbk trottle body, 160 lbs comp all cyl, new iac, tps, checked temp sensor,,,, haven't replaced O2 sensor or atmoshpheric one...... changed distrib with different used one.
I'm baffled
HELP PLEASE
I'm baffled
HELP PLEASE
