DJHA90 Member Dec 17, 2002 581 0 16 Texas Nov 22, 2004 #1 Nov 22, 2004 #1 Has anyone actually built and used one of these DIY systems documented in the tech section? Does it work well? Sorta Work? Isnt worth doing? Thanks
SorsCode 20+ Year Stangneter Jun 10, 2003 1,024 434 113 St. Louis, MO Nov 22, 2004 #2 Nov 22, 2004 #2 Mine is like that. I did it about a year ago. It works. But you have to change it about every oil change because wants it clogs up the oil will start going through.
94GTLaserRC Squint as you approach, lest you be blinded by my 15 Year Member May 7, 2002 11,178 13 89 Ernan Says "here it comes... dushbag" Nov 22, 2004 #3 Nov 22, 2004 #3 I have one that does NOT "bypass" the system, but includes the PCV and allows the oil filler neck to relieve some excess pressure. RC
BlueOvalStangGT Active Member Oct 27, 2003 2,849 0 46 Tampa Florida....USF!!! Nov 22, 2004 #4 Nov 22, 2004 #4 What is it and what does it do
DJHA90 Member Dec 17, 2002 581 0 16 Texas Nov 23, 2004 #5 Nov 23, 2004 #5 It is supposed to keep oil from entering the intake on aftermarket Intake manifolds.
94GTLaserRC Squint as you approach, lest you be blinded by my 15 Year Member May 7, 2002 11,178 13 89 Ernan Says "here it comes... dushbag" Nov 23, 2004 #6 Nov 23, 2004 #6 Steeda sells the "kit" for that, but if you look at it, you can make your own with parts for about 1/2 the $$ RC
DJHA90 Member Dec 17, 2002 581 0 16 Texas Nov 23, 2004 #7 Nov 23, 2004 #7 94GTLaserRC said: Steeda sells the "kit" for that, but if you look at it, you can make your own with parts for about 1/2 the $$ RC Click to expand... And they only want 59.99 for it
