  • SN95 4.6L Mustang Tech
Creepy Caliper Creaking
  • Thread starter Thread starter US muscle
  • Start date Start date Apr 4, 2005
US muscle
  • Apr 4, 2005
Well I stored my mustang all winter considering I live in god awful Connecticut and all.. So I took the stang back out for the first time this year.. I've been drving it for about a week now and i have a *creeeeeeking* noise coming from the driver's side front caliper when the brake pedal is depressed about 1/2 to 3/4 and then when released. It occurs whether the rotor is moving or not and when i put my hand on the caliper as my dad pumped the brakes it felt like the back of the caliper (piston housing/stiff metal brake fluid line) was the part most intensly creeking (vibrating). I figured it just dried out so i greased the slides with caliper grease and all the spring contacts along with some antisqueel on the backing of my pads... no luck.. Any ideas?? maybe flushing the brake system.. Could have some moisture in there causing the caliper to squeek. it's pretty loud too btw you can easily hear it from 20 feet over the flow's ....
H
hbk_136
194
Southeastern GA
Apr 4, 2005
  • Apr 4, 2005
I used some sort of squeak gel/compound on my brakes, and it worked great! Have you tried it?
H
hbk_136
194
Southeastern GA
Apr 4, 2005
  • Apr 4, 2005
Ps
US muscle
  • Apr 5, 2005
it's not coming from the brackets or backing plate on the pad.. the noise is coming from the back of the caliper...
A
AtlanticGT
38
  • Apr 5, 2005
I have a similar problem with my Chev Blazer and have yet to find a solution. Perhaps replacing the caliper is the only hope?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 5, 2005
  • Apr 5, 2005
I'd bleed that one caliper and see if that helps.
If you question the caliper at all i'd replace it. Brakes are important.
Acheron315
235
Charleston, SC
Apr 5, 2005
  • Apr 5, 2005
couldn't it be from the springs of the floating caliper? They are located on the backside of the caliper and could be stiff and causing the noise. If this were the case then you could probably lube them or just replace the bracket, it would be a lot cheaper than a new caliper.
US muscle
  • Apr 6, 2005
There are clip type springs that hold the brake pads in place.. But i don't know of any other spring type devices on these calipers.. I don't believe the slides have springs in them ...
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
ATS brake conversion question
  • stackz
  • May 16, 2024
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2024
Mustang5L5
