REMOVAL AND Installation
Servo Assembly Removal
1. Disconnect servo wiring at amplifier, and disconnect white stripe vacuum hose from dump valve in passenger compartment.
2. Disconnect speed control actuator cable from accelerator cable.
3. Remove grommet and wiring from passenger compartment.
4. Raise vehicle on hoist. Refer to Section 10-04.
5. Remove front tire and wheel on LH side.
6. Remove inner fender splash shield. Refer to Section 47-04.
7. Remove brown stripe vacuum hose from servo assembly.
8. Remove two screws retaining servo mounting bracket to A-pillar.
9. Remove two nuts from actuator cable cover at the servo. Remove cable and cover. Remove rubber boot.
10. Remove two nuts retaining servo to mounting bracket.
11. If replacing servo with service stock, remove two bolt assemblies from front of servo.
