Custom pipping and overheating question
Djstorm100
109
Does anyone have any pictures of their IC pipe for vortech I know you have to run custom. Just wondering if anyone had any pictures so i could get some ideas
would this effect my cooling effect of my radiator?
Also if your radiator has 2 (3/4) core you can say it flows good amount of coolant. If it flows too freelly or easy wouldnt that make it where the coolant couldnt cool down as much as if it was in the radiator longer? Reason being is that when I gun it the temp go up but when I get off it the temps go back down. timing is good on it, no knocks or back fires. I have a fluidyne radiator Was thinking maybe getting a "stock" replacement would better cool the car since the coolant will have chance to stay in the radiator just a tad longer, but that means it will stay in the block as well
An intercooler (air to air) shouldn't have any detrimental effect on your radiator. The Fluidyne radiator you have should cool better than a stocker, even with the higher flow. Cooling has more to do with how well the radiator rejects heat more than how long it stays in the radiator. You could technically have a 12 core radiator, but if it's made of a material that doesn't reject heat well, the stocker could do a better job, if that makes sense?
attachment.php
