Cut and Dry T-5 questions
non WC has the 1-3 gearset just sliding around the mainshaft, and has lower torque rating due to that and other stuff (read up on that link in the 2nd or 3rd post). WC transmissions have needle bearings under the gears and better synchros and stronger parts.
IF you are using a non WC transmission you must fill it with GEAR OIL. don't put no ATF in them things
kiddiccarus said:
All of the SVO's that I have seen that are not in the half year were non WC but the half year when ford placed in the larger injectors the WC was always present it may be just coincidence.
I can understand how the Non WC could be in some of the 85's but not the injector deal. Anyways I'm just going by what I've read on this also. Does anyone know how to tell the difference in these two gear boxes besides the year of the car :shrug: I'm not lucky enough to see a lot of SVOs like some of you but I can check my own car. I know how to tell the years on parts but this is my first stick car so I can't tell one T-5 from the other :(
