Cutting stock springs?
88306stang
87
I want to lower my 93 gt and was going to buy springs but somebody told me that you could cut a coil off the stock springs and lower the car about an inch. Has any one done this or heard about it being doneand what where there results. How was the ride compared to putting in lowering springs.
you can do it but... it will ride like a log wagon.ask me how i know. the spring rate is changed when cutting a spring. it makes it very stiff and bounces from a large bump. driveability sucks.the ride is not worth the work to cut the springs vs. a good set of eibachs or fms springs. buy a good set of springs.
+1!!:nice:
Yeah. Cutting springs = BAD!
Save some money (not much at all) and get lowering springs. Better yet, get some springs and some cheap (but decent) shocks/struts too.
Cutting the springs and keeping your stock crap will make it float about like a boat, probably bottom out on bumps, and could even result in you wrecking your car in the slightest high-speed cornering manuever.
+1 Again :nice:
Hope you have lots of extra hacksaw blades, or a couple of good cutting wheels.
That steel is pretty tough.
It works fine. Since it removes coils, each remaining coil will have to flex more to give you the same travel as before, and therefore it will be effectively stiffer, and ride a bit harder.
Cut no more than a 1/4-1/3 coil at a time, then reinstall and bounce or drive. If more lowering is desired, do it again.
Rears are easy to do this, fronts are obviously more difficult.
Measure the ride height at the fender at all four corners before you do this!
I have FRPP lowering springs in one car, and cut coils on the other, and both seem to ride ok to me.
Use a cutting wheel to cut, a saw takes forever. If you cut too much, get new isolators to raise it slightly.
:stupid: I've done it and its not as bad as some say. Not as good as buying nice QUALITY lowering springs like Eibachs etc. but better than alot of cheaper springs like Intrax, or Jamex or things of that nature. Those WILL ride like a "log wagon". Im not patient enough to do the 1/4 coil at a time thing so I just lopped a full coil. Got fairly low, would probably only go 1/2 at first. Now while this does lower your car, it will ride a bit stiffer and doesnt do much to improve the handline but it doesnt make the car any more dangerous that it was to begin with unless your shocks/struts are worn or something like that, in which case the springs dont have much effect. I would still just buy some nice springs to start with since its not a fun job to do more than once.
