Hi,
You want Rocker travel across the width of the Valve Stem with the Stem’s witness marks as small as possible, slightly off centered is OK if you can reach it with under
</= 0.080 is the Max. recommended Rocker tip travel across the Stem.
If you cannot reach this number, running different Rockers is the next step. Rockers of the same Ratio from different Mfg’s will measure slightly different from Stud Trunnion to Tip than others, then there’s adjustable types, (very expensive).
A slightly off-center Rocker arm tip position is OK as long as the Rocker tip’s travel across the Valve Stem is </= 0.080, maximum
A slightly off-center rocker arm tip position at half-lift is OK as long as tip travel is minimized. Where is your witness Mark at its best now? Have a pic?
The ProComps also had an issue with the Rockers not centering on the Valve Stem from left to right, requiring adjustable Guideplates. How’s your alignment that way?
Cylinder pressures should be 7-10% of each other, 18% is a bit high- but as your Rings haven’t fully seated yet, that’s likely why I’d add some oil to the Cylinders and do a Compression test once it gets in there to make a better temporary seal to see if the loss is related to a leaky Valve or Valve(s). Have you noted any excess play between the Guides and Valves (ones with the light Springs installed)?
Some resources you may wish to review..
FOR TRICKFLOW HEADS, BUT FACTS ARE THE SAME.
OPTIMAL PUSHROD LENGTH/OPTIONS.
Hope that helps!
-John
Hope that helps!
-John
