Cylinder bore prep???
TurboFlush
1,984
Germany
ummm my mind is gone for some reason.
when preparing aengine cylinder for new piston rings and you want to get the cross hatch.
which do you use?
A: CYLINDER GLAZE BREAKER
or
B: CYLINDER HONE
there is no ridge in the cylinders but I do need to bring back the cross hatches.
regards,
TF
so I should just buy a cylinder Hone then?
I know how to use the tool (they are the same, just diff stones), just cant remember what and when each one is to be used. I am guessing a Glaze breaker would be on a higher mileage motor that has a "glaze" on it. the hone would be to then smooth it back out and leave just a light cross hatch.
does this sound right?
When motor work is so expensive, you learn to do it yourself reall fast.
I want that McLaren!!
you only need a torque plate if you are boring it out.
All I am trying to do is return some sort of cross hatch pattern for oil sealing. Only scratch the surface.
I will see how much they want though.
If you are only trying to scratch the surface to restore cross-hatch, a ball style hone is what you want.
If you are trying to properly fit a piston into a new bore by determining it's piston to wall clearance, use a straight bar style hone.
ok I would use a rigid hone when milling off a couple thousandths from cylinder wall either to top off the boring process, or to attempt to return a partially worn bore to perfectly cylindrical.
To scratch the surface up WITHOUT altering its shape, the ball hone is more appropriate.
I stand by my original statement of not using a rigid hone without a torque plate, because it WILL disturb the shape even if only a small mount. My dad and I have done a couple motors with just re-ring and rigid hone, and it just doesn't work out to a good seal.
