And if doing cams because the heads are off might as well do headers too. Cams, ported heads, headers, probably a t-body and upper plenum...now you need to buy injectors as well. It adds up fast and still won't make the power a base supercharger would on a stock engine.
Save up and get the supercharger. The kits come with everything you need including injectors, fuel pump and the tune. Can install it in a day in your garage with hand tools. (Might have to get the fuel pump installed at a shop if it's too much to do in your garage on the floor) Then down the road, if the HP bug bites you again, you can dig into the engine. The difference will be that ported heads, cams and such will give much higher gains when a supercharger is there vs N/A. Although at that point you will need to build the bottom end to handle the power. The stock bottom end is on borrowed time once you hit 450-500hp at the crank.
