Ok guys in the next day or so i plan to fire the beast...
real nervous to say the least, and im in need of help with establishing a check list to pre- fire on a brand new motor w/ a turbo.
Also what do i need to look for when i first fire it.
the car wont be driven or even put into gear. need brakes squared away. along with steering.
so... i have
1. Set fuel pressure (with just the ignition switched) on to 38 psi.
2. Fill fluids
-Coolant
-oil
- Trans
- Power steering
3. Prime oil system.check for leaks
4. Drop in Distributor at TDC with rotor aligned with number 1 terminal.
5.
i put in probably 20 hours in the last 3 days working on this car.
so... i have
2. Fill fluids
-Coolant
-oil
- Trans
- Power steering
5.
