damn this ain't too much fun. 5.4 3v swap
billfisher
1,296
huntsville, AL
update on 5.4 3v swap
forgot the fuel system on this crate. return style means one more thing to figure out. almost ready to pull the 4.6. got it unbolted.
intake requires a butane iron to weld. regular irons do not work. i am just imagining this thing. i feel this is the way to go for getting even with LS's. a couple more days.
i am glad to solve all these tech problems for all to benefit from.
1. short runner intake is easy to do. it does take time and a careful hand. but it will shift the max rpm torque(hp) to 5700 from 5000. i am compiling a list of special tools for this.
2. converting T/B to manual requires manual sensor conversion. removal of motor and drive shaft. adding bellcrank to use factory cable. parts list and fab methods will be listed. T/B is 75mm so use it. also 75-85mm 89-93 5.0 T/B will work also. IAB is built into manifold. fatory harness works.
3. my stang has return style fuel system. good for global tuning with regulator, bad for 5.4 fuel rail. more later.
