dark red frpp injectors ??!???
TheMcCaffertys
17
my friend has a set of frpp injectors that are a very dark red color. he was trying to tell me that they were 36 lbs. but i have no idea and i dont want to buy them until i figure this out. could some one please tell me waht size they are and how much hp i would be able to use them up to? thanks alot
thanks
thanks mike. that was the first post i ever put up on here and that was really fast for a response. could anyone or ever you tell me how much power i should be able to get while still using those injectors? because i want to use them for something. thanks again :SNSign:
Yep, those are 30's, same ones I have on my setup. Those 30's at stock fuel pressure should be good to around 450 hp at the crank, or about 380 at the wheels.
You could always bump up the fuel pressure, but that's usually not the best idea.
Ditto on everything Cmant1914 said. 30lb injectors will be way too small for a turbocharged 408, regardless of the fuel pressure. I wouldn't buy another set of injectors until you figure out exactly what combo your going to go with and what power level your gonna be at.
