datalogging w/ the interceptor
mustangcobra93
928
I am running an Interceptor I. I hooked up my map sensor with the GM supplied harness last night. Tonight I am going to use a vacuum pump to test and make sure it is working (see if it is pulling timing). However, last night I hooked up the laptop to see what would happen when I would try to datalog in boost mode. I couldn't get it to work. All it did was display:
?10
in the little window where the values should be. I pushed F1 to go back to "regular" monitor mode and the program was running perfectly showing me rpms, timing, throttle position, and so on and so forth. Why is boost mode not working? Does anyone have any ideas or had the same problem?
