DCC Fan Controller--Fan Runs After Key Off Adjustment?
  • Thread starter Thread starter ZephyrEFI
  • Start date Start date Aug 10, 2023
First Prev 2 of 2
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,133
2,759
224
Vass, NC
Aug 1, 2025
#21
  • Aug 1, 2025
  • #21
I've had the DCC in for more than a year at this point. I have to say, I have never felt a pressing need to go back and install any switch. Fan works great, and the minute max that it runs after shutting off the car sometimes has never drained the battery or been otherwise noticeable. I do love how it starts softly & doesn't spike electrical load like the fans in my other cars do. I'll probably install one in each eventually.
Regarding your comment Zephyr, I am not an electrical guy, but I believe the diodes purpose is to allow signal to run only 1 way, from ignition to the fan. The diode prevents signal from the controller from feeding back into the ignition circuit. So, if it goes full blast when ignition is on and cuts off when ignition is off, then I'd say you have it right. However, going full blast is obviously not the desired operation.
Reactions: ZephyrEFI and AeroCoupe
AeroCoupe
6,092
4,186
183
Claremore, OK
Aug 1, 2025
#22
  • Aug 1, 2025
  • #22
I have a DCC and Mark VIII fan on the Coupe and when I turn the key on it starts the fan softly runs pretty slow until the car builds some heat. Shut the car off and it spools the fan down over about a minute and like FastDriver I have yet to notice a drain on the battery because of this. I'm pretty sure you have done so but go back over your install and just verify you have it per the instructions. The temperature sensor has to be near the outlet of the radiator for the fan to operate as intended. If the temp sensor is faulty then I want to say it will default to running at 100% but I cannot confirm this.
Reactions: FastDriver and ZephyrEFI
ZephyrEFI
105
22
28
Shakopee, MN
Aug 1, 2025
#23
  • Aug 1, 2025
  • #23
Yeah, that is how it operates. It's no more than a minute that it continues to run. I guess I'm just a bit paranoid about my battery because of how it can lose charge just from sitting (I'm talking months). I feel like if it's died once, it's more likely to do it again. In the past, the car has sat a lot more than I intend that it will once I can use the car the way I've always wanted. If that makes any sense, haha. But I've had batteries die from sitting during warm months too, not just winter. I don't know if that's typical or not, but I've checked for excessive current draw and there really isn't any. Mostly, I guess I just don't trust batteries. It's a known fact that they aren't made as well as they were in the past, lasting 3 years rather than 5 or more.
I hear what you're saying though. Maybe it's a control thing. I MUST HAVE CONTROL. haha
FastDriver
Sep 5, 2001
6,133
2,759
224
Vass, NC
Aug 1, 2025
#24
  • Aug 1, 2025
  • #24
Draining a battery repeatedly absolutely kills it. In both turbo cars, I've got the batteries mounted in the cabin & a cutoff switch behind the license plate. Both of those batteries are 10+ years old, at this point, and still working fine. They're top-dollar NorthStars, though.
Since I'm an idiot all the time, I'll leave the parking lights on at work, or the GPS on after driving home. I smoke the battery in my daily all the time. Fortunately, Walmart has a pretty lenient battery warranty exchange. I pretty much just show up with my 9/16" wrench, 10mm socket & ratchet, receipt, and swap it over in Walmart's parking lot every few years. Honestly, I'm pretty impressed with EverStart cheapos. They punch way above their weight class.
Bottom line, if your car sits long enough to drain 'em, get a cutoff switch, get cheap Walmart versions, or put 'em on a battery tender that will monitor and trickle-charge as needed (CTEK 8-stage deals are my personal preference).
JD1964
there is enough sticking out to grab on to
3,449
1,534
194
Maryland
Aug 3, 2025
#25
  • Aug 3, 2025
  • #25
I have a DCC controller too. Mine also spools down over a short period of time after shutoff.
ZephyrEFI
105
22
28
Shakopee, MN
Aug 3, 2025
#26
  • Aug 3, 2025
  • #26
So, you must've never tried the green wire thing, huh? I've reversed the diode, but I'm still not sure I want to try turning it to run to see what happens... I feel like I'm sort of committed to though, since I ran this wire intending to be permanent, so I did a really nice job, haha.
And I wonder what the yellow wire is for. I hate that the information isn't just available. Nope, it's a secret. The FAQ section you guys were talking about before doesn't seem to exist anymore either. I mean yeah, it probably won't hurt my battery to just leave it alone, but ggggrrrrrrrrr....
FastDriver
Sep 5, 2001
6,133
2,759
224
Vass, NC
Aug 3, 2025
#27
  • Aug 3, 2025
  • #27
Nah, man. I've been daily driving for more than a year. It seems fine to me. I'm kicking that battery's ass, but I don't think it's the fan. I just accidentally drain it a few times a year.
ZephyrEFI
105
22
28
Shakopee, MN
Aug 7, 2025
#28
  • Aug 7, 2025
  • #28
Well, I waited a week for an answer and haven't gotten one yet, so we're going to live dangerously. I turned the diode around and turned the key to run. Nothing happened. So far, so good. Started the car and turned on the A/C. Fan comes on at 50% as expected. Go for a drive. When I got back, with the engine running, the fan kicked on. I turned off the key, and bingo! Fan turns off! I am happy!
Reactions: qikgts, gkomo, AeroCoupe and 1 other person
JD1964
3,449
1,534
194
Maryland
Aug 10, 2025
#29
  • Aug 10, 2025
  • #29
I’ve emailed him twice and got an answer both time but I seem to remember it taking longer than a week. If he does eventually answer, post back and tell us what he said.
ZephyrEFI
105
22
28
Shakopee, MN
Aug 10, 2025
#30
  • Aug 10, 2025
  • #30
Will do.
First Prev 2 of 2
Who Is Up To Date On DCC Fan Controllers?
  • BoostedRed89gt
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2026
revhead347
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
