Deciding my bolt on combo.....
Makdaddymac
323
orlando
alright gang,
ive learned alot from the info here, but wanted to see and confirm what the heads up are on my choice of combos. I want to yield the most hp gain from what i have.....
i currently have 95' svt gt40 irons,a 1.7rr crane cams set .... so those are my choice of heads. since i already have them and got a fair deal on them.....
Now i need a intake to match it up. first choice would be an exploder but i don know if there is a direct swap for the egr and act provisions since im really confused on the whole explorer interchange stuff. I was alos thinking to have tmoss port my upper and lower since it claims to flow better than a gt40 after the work has been done...
so that would be a gt40iron with a tmoss and stock cam. I was thinking of keeping the stock tb. but i could be wrong i could go 65-70mm but dont want to overkill. basically what should i do with my current gt40's and keeping the stock cam....or is inevitable that i should run a gt40 intake:shrug:
A Cobra intake and a 65mm TB would be a good combo with the heads and cam. Like the snowball effect , if the heads are coming off you might as well swap the cam too. A typhoon or trick flow street heat would also work fine too. I would also do a afpr and a phenolic spacer while you are doing the intake swap, if you dont already have them.
ok, yah iwas thikning of just getting the cobra gt40 intake(china) so its just a matter of bolting up make things a little easier and it will be brand new so it will look good.......
as far as gaskets and misc stuff im going to need this is all i have thought about.and need to start ordering....
1) 2 quality head gaskets
2) 2 quality valve cover gaskets
3) set of new arp head bolts
4) lower intake gasket( would i ask for one for the cobra or what?)and the intake comes with the upper and misc stuff.....
5) loctite
how about thread sealer for some of the head bolts
I believe when I got mine explorer intake gaskets, there were some kits that came with both the upper and lower gaskets, and some that have them individually. I wouldn't go to the auto parts stores, those gaskets are about twice as much as like from summit. And depending on where you go, they may not have the one you want, i had to look everywhere. Plus you can get some good felpros from an online store.
i would say no,,,and if there is a difference it should be minimal....
ok so head gaskets are the same, and intake gaskets are the same when using a gt40 head and intake? the only difference is the gasket from the upper to lower. Or is the intake to the heads different(gasket port size different?) i dont want to order the wrong stuff......
i was thinking of just getting this edelbrock set for 108.00 listed under a 1993 cobra? (ps. my gt40 irons are from a 95cobra)
http://info.rockauto.com/getimage/g...l=http://info.rockauto.com/Edelbrock/7364.jpg
and then just ordering the china gt40 which comes with the upper to lower gasket? sound good.....then just a good set of head bolts and im ready!
ps. anyone know the mm diameter on a china gt40 intake.....i was looking to get a 70mm tb....
pss. and will the 1.7 rr clear a stock valve cover???
