Demon blow thru question.
  • Thread starter Thread starter Shakin66
  • Start date Start date Nov 27, 2007
Shakin66
628
Waycross, Ga / Lake James, NC
Nov 27, 2007
  • Nov 27, 2007
I just got my Demon Blow thru carb! I know what I'll be doing tonight. Sorry I just had to share my excitment and also I have a question for you "boosted" guys...Am I going to have to run a centrifical advance dizzy?
rbohm
6,698
550
204
tucson,az
Nov 27, 2007
  • Nov 27, 2007
what some guys do is use the dual vacuum diaphram from the late 70's that had a vacuum retard feature as well. you leave off the vacuum retard hose, and just use the advance part of the unit. when you get into boost, you now have a boost retard unit for cheap.
10secgoal
2,801
San Diego
Nov 27, 2007
  • Nov 27, 2007
Since you run timing low, lock the mechanical section at 18 deg. Then like rbohm said, use the vacuum advance for driving and to keep EGT's down. But no, you don't have to run one. Must just lock out the timing and don't mess with it anymore than that.
Make sure to take that thing straight to the dyno
Shakin66
628
Nov 27, 2007
  • Nov 27, 2007
Does anyone of a good shop in South Ga or Jacksonville, Fl?
jasonn
316
By Rochester MN
Nov 28, 2007
  • Nov 28, 2007
Not saying demons are no good or anything, but you really should take it apart and clean it good. My buddy bought one, (and have heard of ALOT of people having the same thing), and we took it apart and it was FULL of aluminum chips! Take it apart and clean them out first!!! Since, it has run very nicely.
classic boost
709
canton, oh
Nov 28, 2007
  • Nov 28, 2007
yeah- trying to get it to run right.
Shakin66
628
Nov 28, 2007
  • Nov 28, 2007
Yea, it had some chips in the secondary bowls.
Actually it ran great before with the demon I modded out so I dont expect any problems with this actual blow thru set up. If you have a boost referenced regulator that takes care of most of the problems. I have everything I need to swap it to F.I. if it gives me real problems down the road though.
10secgoal
2,801
San Diego
Nov 28, 2007
  • Nov 28, 2007
9psi is easy to tune for. Just have to find some how know what they're doing. Dyno shops around here can't do it. It is different than normal carbs.
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Project Fox Revival (please send help)
  • sleep-e
  • Jan 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
KRUISR
Fuel pump reccomendation
  • jimzzilla
  • Feb 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 21, 2025
85GTStangGuy
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
