Well I think the 650dp is a mechanical secondary so if it's clean inside you could at least use it to test with. Not sure the specs on your engine and drivetrain but I'd guess you'll do better with a 750 vacuum secondary. But the 650 is free so at least try it. I'm not sure but I think if you buy a 750 from Summit and you don't like it you can return it for a refund. I've tuned alot of carbs over the years, from 6 pack setups on big block Mopars to 2 barrel Holleys on 6cylinders. I've changed carbs at the strip from a 650 dp with mechanical secondaries to a 750 with vacuum and picked up 2 tenths with no other changes. It's just matching carbs to proper setups. The Demon is not a bad carb. I've been inside of a couple, they're pretty similar to the Holley. But I'd say I like the Holley best. Mike
