Densencharger CAI
Morpheusgpr
250
Indianapolis, IN
Well so far I love the kit. ITs not installed yet I went to install it tonight but did not have the 11mm wrenches I needed as I bought 10mm as in the directions. THats the only problem I have found so far. That has delayed my install I can honestly say that the stock unit was a PITA to get put back in.
Any tips?
Looks like she should flow alot more. I got the meter 85mm Pro M and forward system.
Do I need to let the gasket stuff sit for any length of time or can I just put it on and tighten the bolts and install it?
Just by the smaller size of the unit it should be easier to check the filter with.
I got it all back in my trunk now had to wrap the meter up the best I could to keep it clean, although it had some silver dust in there from the shop anyways that I could see on my finger when I brushed my finger on the inside of it.
Should that be ok?
Thanks.
Should that be ok?
Thanks.
The black sensor safe RTV provided with the DC will skin over in 5 minutes or less and you should be able to drive the car or at least start it up and check for leaks after one hour. I think it takes 24 hours for it to cure completely though.
As for you MAF... head on over to AutoZone and pick up a can of electronic contact cleaner. Make sure you get the stuff that doesn't leave any residue. Spray the MAF sensor wire prior to installation to ensure it's clean.
U.M.
