Did I fry my voltage regulator?
  • Thread starter Thread starter nopho85024
  • Start date Start date Jan 25, 2007
nopho85024
10
  • Jan 25, 2007
If anyone can help I'd appreciate it. I was installing a new JME gauge cluster with autometer gauges last night and one of the leads to the old ammeter (which is not used in the new set-up) sparked against the steering column. From that point on my headlights didn't work. Everything else works fine, however, even the front parking lights.... no fuses are blown under the dash either..... and everything is stock...
Could I have fried my voltage regulator????
Thanks,
geostang351
946
Danb., CT
Jan 26, 2007
  • Jan 26, 2007
Thanks,
I believe the headlight switch is a circuit breaker itself. You probably need to change it out. If the gauges continue to function, the voltage regulator is still working.
nopho85024
10
  • Jan 26, 2007
Thanks. I was thinkin about it for a few hours and I was coming to the same conclusion - that it probably shorted the headlight swithc. Luckily I have an old one that is in working condition. I will swap it out today and see if that works....
D
D.Hearne
11,730
south louisiana
Jan 26, 2007
  • Jan 26, 2007
You might have a fusible link in the circuit that shorted. These were incorporated into the wiring harness in some cars. I don't know if the Stangs had em or not though.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12 minutes ago
DadLife0724
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
