cb18201 said:are the ati intercooled prochargers any good? they seem like they would be because you dont have to use your engine oil for the p1sc and its intercooled. anyone run these? ups? down?
swingline said:I would just go with the tuner kit and run 42's and a big pump. Then get it tuned. I would rather depend on my tune and hardware. If you're running the FMU with wimp-dick injectors and pump and the FMU fails; you're in trouble.
jtkz13 said:Noone has answered my question on power production. What would a reasonable estimation of rwhp gain be for 8psi from the V2 SQ & a good tune?
its advertised as 6-8 but with a power pipe and the right cam its more like 8-12willys1 said:How many pounds of boost with that kit?
Road_Runna said:What's the difference between a V1 and and V2 ? (or whatever it's called)
I've heard the the SQ's don't need any feeds from the oil pan, is this true ?
And finally where do you take it for a tune ? would buying a chip be better ? Does the gas tank need any gaskets when your installing the gas pump ?
I might get a kit in 3 months, if everything goes smooth with my car.
jtkz13 said:The V2 SQ has a different gear design which makes the blower dang near silent except for a tiny whistle. The V1 is loud in comparison and I think has a slightly different 'step-up' as far as the gearing goes. I remember reading that awhile back, so dont take that as fact.
I believe both need to have an extrenal oil line from the oil pan tapped to feed the charger
I suggest taking it to a reputable speed shop in your area, and have them dyno-tune it and burn a chip. As far as the pump goes I dunno, I need to do the pump myself.
Joes95GT said:And that's the part I don't understand.
Riddle me this: In heads-up racing (NMRA Real Street in particular), why are Paxtons required to have a bigger pulley on the supercharger than any others (less boost)?
Just trying to start trouble....
Joe
The Novi 2000 is a monster blowerGreenMustangGt said:yeah i have that question also about will an fmu work with a modded car, say mine, i still have the stock injectors, with my explorer motor...would an fmu be good to me? that way i wouldent have to get it tuned!?
