Diff. between Bilstein Heavy Duty S/S
AmBo
1,027
New Jersey
Was wondering if there is a large difference between Bilstein Heavy Duty Shocks/Struts and the more expensive ones. The heavy duty one's can be found for $465 shipped. That seems kinda cheap for the "Bilstein" name. No? :shrug:
Hell, I just want my very to NOT drive like a big wheel... :rlaugh:
non adjustable compared to adjustable. the nons being much cheaper.
i went with the tokico non adjustable shocks and struts with the billstein quad shocks for lowered cars and love the ride. Not harsh at all but no way near as sloppy as stock.
where did u pick all this up? I have my vert lowered with springs and the rest is stock. The ride is HORRIBLE! I need serious improvements. What should I get? I'm going to buy Bilstein Heavy Duty shocks/struts. What else? c/c plates?
Lowerin on stockers....not a good idea. Go with the H D Bilsteins. They are made for lowering vs. the sport bilstiens that come with the 03/04 cobras.
i bought all my stuff for my suspension from steeda
www.steeda.com
i picked up their superlite springs to go with the tokico's, also added the aluminum upper/lower rear control arms and the 03/04 cobra front control arms with ball joints. You can find the stuff cheaper if you shop around but i like their customer service so i'm willing to pay a small fraction more.
AmBo said:
I'll have to look into it. Hows the ride quality? Like a brick car?
no not at all, it handles great around turns and doesn't do such an extreme nose dive when you get on the brakes.
my ride quality absolutely sucked before i swithched the shocks etc, i had the original crap in for 90,000 miles and they were trashed. So the ride is actually better now. These are quality pieces i used so when your hitting bumps they actually rebound better then the stockers give you a nice ride. Its not like being in a Viper where you feel like your teeth are gonna fall out when you go over train tracks or something.
you just have mis matched setup right now. you have you struts are running 1.6 inches compress with a spring rate they are not valved for.
I would look at the bilstiens. if you want to be able to soften the ride you could look at the tokico illumina fox body setup.(1"shorter shocks and struts)
the tokico hp's are suppoed to be equivelent to the illumina's on seting 2 or so.
I went with bilsteins due to them beign designed to work on lowered vehicles.
one thing to remeber is you have 1.6 inches less travel than you used to and you will have a stiffer spring rate than you used to so it will ride stiffer no matter what you do. there is not magic when reducing travel and adding rate.
the people who say there ride got better probably had shot equipment. I did my stuff at about 20k. The stock stuff road very smooth but handled like ass so I did not mind being stiffer. great handling mustangs don't ride like caddy's.
Understandable. So should I get the tokico HPs or Bilstein HD? The Tokico's are $120 CHEAPER. Isn't that a bad sign?? My inclination is that the Bilstein's are what they use on the cobras, so why wouldn't I use them as well? ;-)
just cause something is more expensive doesn't make it better..BUT billsteins are very good product and worth the money.
