Differences in roller timing sets, earlier vs. later?
What is the differences between the earlier and later roller timing sets? I have a new set that says it's for 62-82. I am putting this roller cam block together now and time to put on the timing set I had stashed away. Will this set work with the roller cam or do I need a roller cam specific set? Where are the differences at?
so an earlier double roller timing chain set for a flat tappet cam will work on a roller cam block while using a roller cam? the set i have is just a heavy duty double roller timing chain set listed for 62-82 302's. is there an actual difference in how the earlier and later sets fit besides the fuel pump eccentrics and different lengths cam pins?
no difference your fine, they are specific on big blocks as the smog era chain sets had 4 degrees retard built into them for emmissions. Throw it on and roll
